Thinking of selling my 355 ci motor out of my 67 rs/ss camaro. It's a 350 bored .030 over with Keith black pistons. 12cc dish. The block is a 69 camaro block. The crank shaft is a true steel 67 crank 1182 turned.010 on both rods and mains. The heads are 1965 camel hump heads with harden seats and 2.02 intake stainless valves . And comp cams springs that came in the cam kit . Cam is a comp cams .454 lift. The Rods are scat rods rated for 450 h.p with ARP bolts. The engine is balanced also. I have the receipt from the machine shop and all the boxes for the parts. Also have pics of the engine parts before it was put together.
