I've installed a RS Conversion kit on my 67 camaro. All was smooth sailing until testing the operation of headlight doors. The doors close fine - headlight door strikes limit switch and motor shuts off. Opening doors if fine too until it strikes limit switch on radiator support. Motors won't stop running - left and right side. When I push switch with finger they will stop but the doors by themselves don't seem to "lean into" or "power into" button like they do when closing. I've swapped switches and checked wiring and I think it is ok.
Are the friction discs/pressure critical? Is is power related in some way?
jeff
jeff
