Just about finished with my 68 SS, but I have a major problem which is the hood clearance, or I should say no clearance for the air cleaner. Details as follows:
My 68 has the factory SS style hood, not the cowl hood.
Engine: 396 Big Block.
Intake: Edelbrock Performer
Carburator: Edelbrock Performer Series, with Electric Choke.
I think the problem may be with this carb having the electric choke, which is mounted at the top of the carb, so I don't believe there is a drop base filter bottom out there that will clear the electric choke! (Edelbrock confirmed that with me yesterday!)
So Edelbrock recommended their triangle shaped filter assembly, which would clear the electric choke, but depending on which style I choose, the filter is still 3"-3.5" above the top of the carb. Hell, I'm not even sure if I have 2" clearance between the top of the carb and the hood.
Does anyone out there have a performer intake & carb on their big block, and were you able to utilize a standard SS hood?
So the initial problem MAY BE due to the performer intake as it is higher than the factory intake. But if anyone of you guys out there have experienced this issue, what were you able to do to solve the issue?
Any suggestions would be greatly appreciated!
Thanks!
Dan
Thanks!
Dan
