68 Quarter replacement
1.1K views 4 replies 4 participants last post by  Frank350
going to replace my quarters and don't want to have to buy factory ones. what aftermarket brand fits best
We used this from firewheel classics:
http://www.firewheelclassics.com/store/item.asp?Category=55&SubCategoryID=83&GroupID=&SKU=QTR01_02
I believe they are AMD as most pieces sold from firewheel are AMD.
They were a good fit.
Also, if you intend to have a higher power engine installed, I would HIGHLY suggest a set of subframe connectors, and def. replace all of the body mounts.
Even with a great instillation, a high-po motor flexes the body alot, and the quarter panels are extremely prone to cracking if they've been replaced, good insurance, and you can't really see them unless you really look hard, shouldn't cause too much problems if you're going for originality.
I just installed a full RH AMD quarter panel and NOS outer wheelhouse. It was a first time experience for me and was amazed at the results and fit. It is, for an amateur like me, a large projects because I was VERY afraid of not doing it right. It took me many many hours, lots of measuring, fitting, thinking, etc etc. Do it once, do it right, the level of satisfaction once it's over is very high, I can tell you that. Threads, builds, and member's advice here on this forum are what made it possible. When you don't find direct answers and/or pictures, go ahead slowly, some steps are self-explanatory. Good luck ! Frank.
