I found this car, it's about 5 hours away. I'm going to look at it. I'm hoping to get it finshed for about 8K-10k.
The money would be spent on..
M22 trans
12 Bolt rear with posi
Finish and install the motor
Finish the interior
The orange motor is a 350 converted into a 302, looks rebuilt and he has most of the parts for it.
The other motor is an older 350 crate engine, which should be ok, would just need to be cleaned up and made to look period.
The interior needs new foams and seat covers, he has the frames. Would need carpet and door panels. The dash would have to be wired up, painted black and installed.
The paint is oil based, maybe enamel. Owner said it has two coats of color and one coat of clear and he added some metalic. The stipes are charcoal, not black.
According to the owner he has everything except the trans and rear, and the interior pieces. He says he has everything else, trim and chrome etc.
He has the vin, trim tag and title from the donor car which was a V6.
He says he has spent 25K on parts, I'm not sure if that included the donor car.
So the idea is to have pretty close to a new car when it's done. I'd put in the 302 and put on Z28 badges, not sure what HP that 302 motor would make though.
Some pictures are older, he has continued to put work into the car, he just had the glass installed, I'm not sure if the steering column is in or if the front end is connected.
Would this car be worth 30k+ when its done?
Please reply, I'm making the drive with the money in my pocket.
M22 trans
Finish the interior
