Hey guys,
I have a small block, 350 69 camaro coupe. I didn't notice until I took the front clip off the car, but my fan shroud is just loose at the bottom. The shroud does have some tabs on it that extend horizontally about an inch. But I don't see anything to mount the tabs to. There are no screw holes. Should the shroud just be loose down there like that? I've never seen it flopping or vibrating, but it just seems strange for the shroud to be fastened only at the top. Am I dealing with an incorrect shroud? By the way, it doesn't quite cover the fan. I'd appreciate any info and/or suggestions. Thanks.
