69 disc brakes on a 67??
1.1K views 4 replies 5 participants last post by  ohcscott
I have a 67 with original disc brakes, however I do not have the calipers. I was told by a local shop that I can use the 69 rotors, calipers and wheel bearings and it will fit just fine. Is this correct? I would rather not go out and buy a whole kit. Any input would be useful....thank you.
You'll have to get the 69 caliper brackets.
Check all tire/bumpstop clearences at hose/caliper at full steering lock left/right at full suspension compression and droop. Don't find out the hard way that a hose rips off or wears through.
67 bumpstop on frame can cause issues.
67 disc line J bend and bracket location may cause issues.
Using Chevelle calipers might help solve both issues on the 67s.
The hose inlet is on the bottom.
I have them on my 68, and they're what come with most disc kits.
