I saw a couple of videos showing the 8.5 rebuild. one video said that you set pinion preload without the carrier in place and you want about 20 in/lb of force to keep the pinion moving (not starting rotation). Then after the carrier is in place and shimmed the preload will increase maybe 5-8 in/lb higher. The side bearing preload is the difference of preloads (5) x the gear ratio (3.73) = 18.65. It said you want this to be from 5-35. This is all with the old crush sleeve. Then after getting the proper gear patterns you put the new crush sleeve and seal in place and tighten the pinion nut to force the crush sleeve.
If preload is different depending on the amount of shims on either side of the carrier, what would be the preload at the point of final assembly? I think the Yukon spec is 16-19 in/lb. Is that with or without the carrier and shims?
thanks
Rob
thanks
Rob
