I have gotten three different answers from Powermaster, MAD Electrical and American Autowire and I don't know which one to do. Can you help??
Heres the situation: I have a fairly new(2 years old) wiring harness from Fatcory Fit that includes the external voltage regulator and the resistor wire was replaced for my MSD box, I do run the diode now. This weekend coming back from the Goodguys show, I slowly lost the alternator and all my lights went dead. This is the 2nd Jegs alt in 3 years. Jegs only had the 1-3 wire int. regulated alternators in stock so I bought one and ran a wire to the battery just to get me home safely. Now I want to go back and try and redo all this and hopefully not cut up too much of my wiring harness.
I ordered the Powermaster 100 AMP 17296 alternator, and they say I need an 8 gauge wire right to the battery. MAD electrical says to just piggy back the current 10 gauge wire from the alternator to the horn buss with another 10 gauge wire, that way I am not butchering up my harness and it will keep the car real clean.
Factory fit says I can use the current 10 gauge wire in the new harness and I will be fine. This does go the battery but it stops at the horn buss and the junction block behind the battery too along the way.
What is the proper way to do this and keep the car real clean? I do want to get the #150 (Voltage regulator conversion kit) from Powermaster to run my GEN light and stuff like that.
What do you guys suggest or what have you done to keep it real clean.
Thanks, Erik
Thanks, Erik
