My 327 is toast...Next weekend I am going to my engine builder to get a 355ci build started for my 68.
I drive the car maybe 2000miles/year, and I've always wanted a solid roller with some serious midrange pull that revs hard to redline. But I don't want to have to wait for power to build. Idle, say 800-900?
I'm committed to the 355, as its already at his shop, newly built, and gave me a good deal on a 355ci 10:1 (or higher if we mill the heads for compression)
Forged pistons
Carry-over from my 327:
200cc Aluminum Pro Toplines, 64cc chambers
1.52 Pro Magnum Rockers
Weiand 7546, tall-ish dual plane manifold.
600cfm Edelbrock (which I will ditch for a 650+cfm asap)
1 3/4" Dougs headers
Drivetrain:
TKO 500 5 speed
3.73 rear end
Street tires.
Here are the cams I think will work well:
COMP XR274R
INT EXH
ADV: 274 280
0.050: 236 240
Lift: 0.564 0.570
LCA: 110
ICL: 106
or
COMP XR280R (uses the sames springs as the 274)
INT EXH
ADV: 280 286
0.050: 242 248
Lift: 0.570 0.576
LCA: 110
ICL: 106
I'm looking to build a healthy combination that is flexible, yet aggressive. The engine builder didn't even hesitate to recommend the XR274R, so I am wondering if the 280 would be worth it for top end power. With my steep gearing, I am even considering a Victor Jr. if
it wouldnt hurt the 2000+rpm power.
Power Goals:
460+ HP
Peak TQ around 4500rpm
What do you think?
Thanks!
Steven
Forged pistons
Drivetrain:
TKO 500 5 speed
3.73 rear end
Street tires.
COMP XR274R
INT EXH
ADV: 274 280
0.050: 236 240
Lift: 0.564 0.570
LCA: 110
ICL: 106
or
INT EXH
ADV: 280 286
0.050: 242 248
Lift: 0.570 0.576
LCA: 110
ICL: 106
Power Goals:
460+ HP
What do you think?
Thanks!
Steven
