Hi!
I also posted on another thread as the discussion made me re-think about my own issue and possible solution...
I don't want to jeopardize so I open here a new post and describe my situation.
I had previously solved a grounding issue between T56 case and tunnel, but I noticed it comes now again (only under heavy torque, in 4th full power 4500 rpm).
After thinking about it yesterday and considering david pozzy note I believe there is something to do : improving the engine mounts
Camaro Engine
I currently have 1 low perf rubber mount on the driver side + 1 energy suspension 3.1114 PUR mount on the passenger side.
I also have the low perf frame brackets.
There is room for improvement :
https://www.speedwaymotors.com/AMD-...tors.com/AMD-R-270-69-Camaro-69-74-Nova-302-350-Engine-Frame-Mounts,296191.html
What do you think?
I ‘d like to hear your advice based on your experience shared 😊
Camaro Engine
- Interlocking type (In 1969 the factory installed interlocking mounts on the high perf engines only. These mounts are thicker and required a shorter frame mount to keep the engine where in the correct position.)
- Keeping rubber (I installed previously 2 x 3.1114 energy suspension PUR and I didn’t like it, too much small vibrations)
- Lowering the engine a little bit, so it will clear the trans tunnel + it will help with driveline angles. (the 3.114 is taller which slightly raise the engine)
- Change the transmission mount back to rubber (I believe I have a PUR one) + this help prevent cracks in the transmission case is that a real concern or not?
What do you think?
