OK, I'm looking to get some input from you guys since I find a wealth of knowledge one this site. Here's my question? I have a 69 Z with that factory 302 in it. I've been thinking about trying to kill 2 birds with one stone, by pulling the 302 and storing it for safe keeping yet also replacing it with something more potent. I'm curious to know how much fast my car would be in the 1/4 mile if I was to replace it with a 350 that is built very similar to the 302 i.e. 11:1, solid lifter cam, etc... Better yet say that the 350 was built exactly like the 302 same heads, cam, compression ratio... Would there be a big difference in quarter mile times? My set is 4 spd and 4.10 gear. The car has no power steering or A/C (true Z car). Any ideas what it would run in the 1/4 with the 302 (not had a chance to run it yet). Thanks so much...another note, if I did plan to replace it with a 350, I would likely go with flat top pistons, aluminum heads, either solid lift or hydraulic roller..
Forgot to mention that I have access to a 355 with flat top pistons with zero miles on it since rebuild. Engine is still on stand and needs heads & camshaft...
Thanks again...
[This message has been edited by lakemg (edited 11-24-2002).]
Thanks again...
