Heck of a time putting calipers in on my right stuff rear disc conversion. It's '67 with 10 bolt. Kit comes with three thickness of spacer plates. Directions say use the thickest plate to start with and drop to thinner or none at all if you need more space going out. After trial and error, went with zero spacers. But it was still really hard to try to keep the discs in place while installing, so I decided to try with only the outer disc just to be certain not using any extra spacer is right tolerance. To my dismay, the outer pad is too tight even to move the caliper on. The pad hooks are in the right place, so it's not sticking out because of that. In the enclosed picture, you can see that I couldn't even get the caliper fully on because it's so tight. I've only tried the passenger side.
It looks to me that the axle is at least 1/8" too long, and the axle could be as much as 3/8" shorter.
I haven't called customer service yet, but it is pretty evident that the axle sticks out too much.
Do I really need new, shorter axles? Really?
Thanks!
Mark
Thanks!
Mark
