So, I've been trying to track what I thought was a parasitic loss. Tested my battery and found out it will not hold a charge. Hooked up my Fluke meter and saw it had discharged to 11.8 volts overnight with the negative lead removed. So it's dead. Bought a new Die Hard and dropped it in. Checked battery voltage and it read 12.2 so I assumed it was not fully charged. Put the Battery Tender on it and brought it up to 12.6 , should be fully charged right? Removed the negative lead again and immediately watched the voltage drop to 12.2, 12.1. Is this normal with a new Battery? Why doesn't it hold the 12.6 charge?
