There is alot of good info here and most is true. I've ran 990's,188's,840's PLUS every Oval port GM ever made. Ovals will be better for a street car no doubt, but if you have 3.73 gears or better,and a loose converter or stick,those 990's will produce. Easily,and without any work. I've gone 10.60's with stock 990's @ 3600lbs with a .600 lift solid cam so they can make great power, but as everyone is saying.......Ovals will be better on a heavy street car.Torque will make it feel fast, My 71 chevelle with stock ovals and a .520 hydraulic cam flat out hauls !!!!! Never ran it but i bet mid to high 12's. I recently sold a set of 188's which is a later varient of the 990 for $650 so the have some value to them also.Although people say their the same,i think 990's are a better head. I almost forgot to mention........ i broke EVERY rule when i built the 454 for my 69 camaro conv. 9.0 compression, .566 lift 242@.050 cam, stock 990 heads, 3000 converter and 3.08 gears !!!!!!! It ran and felt awesome and ran 12.68 @109 street tires thru 2-1/4" exhaust.I could almost run the 1/4 in second gear !!!!!
To answer your question.......In my opinion....DEFINATELY WORTHY OF USE. Unless its a heavy/non performance street car, then trade em for a good set of ovals.
bob
