hi ,
i built this 383 with 10.8-1 compression, 216/216 - .454/.454 cam
on a th350 (stall 2500rpm) equipped, 2.73 rear 3rdgen.
its detonating like crazy, so i was thinking of going to another cam.
im limited to .480 lift MAX.
i looked at a 230/236 - .480 .480 cam
or a ISKY cam with 244/244 - .450 450. 106 degree
is the ISKY to much? its powerband is 2,800-7000.
im afraid the 230/236 is still to mild to run without detonating
i might get some shorter gears in the rearend near the future, and i dont care about a little lag of power at low rpm.
(enough vacuum for the brakes would be nice though)
i cant change heads or pistons.
