guys any tips on how not to get your cleaning towel ripped apart by the surface after media blasting?
i have fibers stuck to the metal everywhere
No need to clean freshly blasted metal. Blow it off with compressed air and shoot your epoxy primer. If you can't live with that then wash it with water and Dawn dish soap. Blow dry with a leaf blower. No need for anything more imho.guys any tips on how not to get your cleaning towel ripped apart by the surface after media blasting?
Depends on humidity but no amount of cleaning will stop it from flash rusting in high humidity. If you are short if time skip the washing and use the time to epoxy prime it.Even if it wont be for a few days before i can paint? Its only on the door jamb areas so i can re blast and clean day before
I've had parts of my car in bare metal for years in a sometimes heated garage. I use a ventless furnace when I do heat which supposedly adds moisture to the air. In the last year I've started to see surface rusting begin. I'll reblast those panels before I prime. I really think Don is right, Blast it, squirt primer and paint on it and go. Highly unlikely that it will ever need redone in your lifetime.Depends on humidity but no amount of cleaning will stop it from flash rusting in high humidity. If you are short if time skip the washing and use the time to epoxy prime it.
I am guessing your car will never see rain let alone road salt again. Don't over think this stuff. Get at it, get it done and enjoy driving your car sooner....
Don
I'm going to suggest a proper wax and grease remover versus mineral spirits.Rub down with a scotch bright pad, blow dry, mineral spirits, prime.
Read a tech sheet for a chosen Z C., and the epoxy within the same company in the automotive repair industry.If its body panel I'd do like 327fuelinjected says.
On a subframe, just give it a good going over with 150-psi and epoxy primer it.
I went through 5 Navy Ship Yard Overhauls where they blasted the ships hull with 80 grit Black Beauty Abrasive, air cleaned it, applied Zinc Chromate, Epoxy, then Hull Black Or Navy Gray. The paint underwater fared well for 8 years
