You need an AIM (factory Assembly Instruction Manual)
Basically a hose runs from the tank on the pass fender and is strapped to the upper heater hose (non-AC car) to the firewall and through the wire molding to the wiper motor/pump. In an AC car it is strapped to refigerant hose then the AC harness back to the firewall.
From the pump you run a hose back through the molding to the squirter on the pass side and and a hose from the pump over to the driver side squirter.
From the two headlight squirters on the pass side the hoses T into one hose that is bundled with the vacuum hoses under the radiator support. The driver side squirters T into a hose that T's into the one coming from the pass side which basically continues along the driver side fender with the vacuum hoses for the headlights and then is routed to the pump as it gets to the firewall.
