I have the stock dizzy in my 67 that has a Pertronix module. Worked fine on my 327. Now with my new 355 motor that makes about 15" hg vacuum at idle (220/224 cam) I need a VA can that is adjustable to operate at lower vacuum. Crane makes a kit:
Which one would I use with a points dizzy using a Pertronix module?
points Crane Vacuum Advance Kits 99601-1
or
HEI Crane Vacuum Advance Kits 99600-1
The dizzy with total timing set at 34 gets me 11 degrees base timing but with VA hooked up its like 30-34 degrees of timing at idle as it appears the stock can is allowing around 20-24 degrees of advance. With that much timing shut off results in dieseling so I am now not running VA. No issues in drivability without it but I need more timing at idle for the leaner condition to burn better
Also I suspect the 53 year old springs in the stock dizzy are tired so swapping those out to a stiffer spring would likely benefit and keep total timing from not coming in to early as it does now
Any comments on the Crane, or other, kit appreciated
BTW, excellent read I found in search by John Z on VA
or
