Sorry, been away...it is the basic Right Stuff 14 inch wheel kit. I did have the upper arms off the car. I took them off by the two nuts where the adjustment shims go in, did not loosen the bushing part. I put them back on with the shims in same location and torqued to specs.
Did one side up at a time, with jack under control arm. I can't roll car back and forth, in gear and I have the interior gutted, clutch pedals and all removed. E-brake removed so trans only thing keeping it in place (on flat ground). I tried with a little force to put in N but not going and do not want to have problem if I put in N not getting it back in gear. I did bounce up and down on the car with level on tires and the bubble did move a little towards center.
I just re-read everything again and see were John mentioned ride height and weight...I did not realize weight would change tire tilt. I have the entire sheet metal off of the front, fenders, hood, core support, steering box, etc...Perhaps that is it although before I started, with everything off but drums still on there it looked good, but, car had been driven, parked, and not jacked off the ground with sheet metal removed until I started the swap.
I have to have someone weld in new dash before I can put back together so will have to wait but thinking once everything is back on the tilt will look better. There are only two shims on driver side so not much room for adjustment, passenger side has five. Alignment shop is maybe 15 miles away.
It may be awhile but once together I'll update, thanks for all the replies,
Dave
