Is there a common problem with the 69s front end that causes the entire suspension to shift to the passanger side of the car? I have almost 3 fingers between the wheel and the lip of the fender on the driver side and only about 1 finger on the passanger side! I picked 2 other 69s at random last night and noticed the same on both. I pulled the wheels and verified the offset (4") and everything visual looked ok.
This all started as I have so rubbing in the front with passangers in the car. There is no rubbing when flying solo...
On the driver side the inner front is rubbing the frame when making a right turn. and the passanger side outer front rubs on the firewall side of the inner fender. The car drives straight and doesn't appear to crab walk.
I have 15X7 4" offset wheels with 235/60's on them. I was told the springs are bigblock that have been cut to keep the ride hight close to stock. Click here for a picture
Should I just go to 215's to resolve this? Any feed back welcome please...
...Dennis
Topless'69
Camaros Limited Nor-Cal
rsss.fun@gte.net
...Dennis
Topless'69
rsss.fun@gte.net
