Gen6 Cam in a Gen4 BBC - Been There?
1 reading
16K views 10 replies 5 participants last post by  Bono454
Has anybody fitted the above? I've been handed a hydraulic roller cam (Comp XR294HR) from a ZZ502 and would ideally like to drop it in my Gen4 454. Can this be done positively?
I've been told it can be used happily if you use the timing kit and retainer plate from the ZZ502.. (Eg - Summit 12371053)
BUT.. I also just got sent this response from Comp Cams tech support:
" It doesn't work because of the smaller bolt pattern and needs to have a retainer plate set up for that particular camshaft and the base circles are different for the late model versus the old style camshaft etc."
Can anybody speak to this from first-hand experience? (As opposed to rumour and hunches :) Assuming the timing gear swap relates to the 'bolt pattern' but what does "base circles" mean?
The rest of the setup FYI; Holley 750VacSec (3310), AirGap matched to ported ZZ502 rectoval heads #6045, tri-Y headers, 2.5" twin system, T350, 3.5 gears. (Will need to change 2500 stall to 3000 for cam). Don't know compression, internals assumed std 2-bolt 454. Is streetcar with trip to drags few times a year.
Oh, I also heard the standard ZZ502 cam works a treat in a 454.. But this Comp one has a wicked loping note by looks. Anybody seen/heard/driven either?
Cheers heaps in advance guys!!
Yes, the Gen6 cam bolts into a MK IV block with no issues. In fact, its the way to go. You need a Gen 6 timing set, which comes with the retainer plate and bolts to properly retain the cam. Your block should have 2 tapped holes on the block for this already.
OK.. so what is with COMP"s reply then?
And I'm a bit naive in this area sorry, so not sure what "the base circles are different for the late model versus the old style camshaft etc." means?
Is the Summit parts at that link all I need different, or potentially more bits? (inc pushrods etc).
Cheers!!
Also, make sure your block is drilled and machined for the thrust plate (retainer plate). Most MKIV's are, but some are not.
And yes you need to use the retrofit lifters.
There was just a Letter to the Editor on this in one of the mags (Hot Rod, Car Craft, or Super Chevy). Basically saying that this will work, given the right parts are used. There is a new double roller timing set that is made for the Gen6 cam, and will fit under the MKIV timing cover (I believe it is a Comp Cams part).
Deano,
You have to use the retrofit roller lifters. The early blocks are not machined to accept the Gen6 style roller lifters.
This timing set you linked to looks like the correct one. I did not realize they were that cheap from GM :)
I have the part numbers at the shop for the retainer plate and the screws, I will try to remember to post them in the morning.
#11 ·
Hey guys, just wanted to thank you all SO much for this input.
But the rest of the deal (heads/intake) just fell through due to damage & though simple to you guys, this is just too much brain damage for my little head. Will start looking at a solid flat tappet (designed for MkIV) for simplicity I think.
Cheers heaps again anyhoo :)
