Going to try Sandblasting in my garage, have a ( possibly stupid) idea.
I have the car WAY up on stands and everything pulled off the underneath, engine and all drive train and suspension off.
I bought a sand blaster 10lb pressure pot from Tractor Supply and a few bags of Black Diamond abrasive. I bought larger hole size replacement nozzles.
My plan is to wrap clear plasic around the car taping it to the sides and letting it hang down onto the ground sealing the car (with plastic all the way under to recover the abrasive).
Putting the hose and gun under the plastic and rigging lights inside to see I plan on slicing arm holes in the plastic and trying to blast while staying outside the bagged car. IF THIS WORKS, I will seal the holes with tape and move along the car blasting the underneath.
I hope this works, I may find after the first minute a horrible flaw in my plan, such as can't see well enough, can't reach in far enough etc.
I plan on starting tomorrow morning and will post results good or bad.
Ray
Ray
