I need to make the 1 1/4 inch antenna hole in my fender and many of the posts state to use a greenlee punch. Want exactly is this? Do you need to purchase the punch and the 1 1/4 inch bit? I searched google and I still do not understand what this tool is and what I need to buy. Any explanations would be appreached. My fender is installed and it looks like you drill a pilot hole and assemble the cutter and base on either side of the metal which means no good for a installed fender. I guess I can take off the fender again :-( if I have too but alignment is so much fun I would rather not. If the punch is not the way to go what other suggestions would you guys have?? Metal hole saw attached to a drill??
As always thanks!!!
As always thanks!!!
