Use the Tie wraps to do the initial positioning of the covers to the seats, start to adjust the covers so the fit is correct and then one by one pull the tie wraps tight, adjusting the covers as you go. Then, when everything is adjusted and fits correct, start replacing the tie wraps with the hog rings. Install a ring, remove the tie wrap, etc. The tie wraps allow for adjustment and fit, the rings are better long term.
