how much horse power with the SPORTSMAN II heads? any one try em??
21K views 23 replies 11 participants last post by  DOUG G
well here is what my car has right now and what it runs right now , it is a 406 sb with dish pistons ,76 chambered 2.02 -1.60 heads , with 1.5 aluminum roller rockers , a 481 to 490 lift cam , rpm performer intake, 750 holley vaccum secondary , 1 5/8 headers , 3 inch exhaust, and behind is a turbo 400 with a 3000 stall and right now it is running a 14.39 at 94 mph due to my low compression but with the sportsman II heads what should i expect they have 200 runners , 64 cc chambered , 2.02 1.60 valve size i was thinking with more compression and better breathing i should reach a 13.60 at 100 or am i way off the heads on there now suck come to find out for flow any ways o yeh and also would better flow mean more RPMS
we are ordering them tommorrow if yall know of a better head for the same price tell me we found some for $750.00 brand new fully assembeled thanks agian later guys.
[This message has been edited by camaro79tx (edited 04-22-2001).]
With the II's try and get a bigger valve size. They came with 2.05 and 2.08's. My 383 loves the 05's. When ported and polished they run great.
Mark
1992 Firebird 355/Six Speed (Soon to be LT1)
1991 RS 350 / 700-R4
"Speed KILLS, so drive a FORD and live forever!"
Member of the "unwanted" 3rd Gen group.
they have a good reputation, but if you look at the flow numbers they are good, but aren't spectacular. As was said before, the exhaust port could use a little work. Of course, my flow numbers are a year or two old and the castings might be different now.
The trick flow 23 degree heads run about $850 or so from summit...they have a little better flow numbers than the darts...plus they are aluminum (less weight). Any of these heads will give you at least 50 hp over the 76cc 2.02's your running now...and that cam will like the extra compression from the smaller chambers. I think that with any of these heads and a bit of tuning 13.5's can be easily reached.
375hp 78 Chevy truck
77 Chevy Nova
95 Chevy Lumina 3.4L
and building a 78 Nova
Thats a pretty good 60' time...you should see power gains everywhere, especially above 3000 rpms or so. I dont think 100mph in the 1/4 will be too difficult
77 Chevy Nova
#13 ·
Well a TH400 takes about 50 extra horses to run over a th350. I'd say have a reputable shop build you a good TH350. Do a search, there's something that needs to be hardened in em but I can't remember. I had mine done for $500 total and it chirps the tires shifting 1st to 2nd. I can get one for like $300 though but I chose to go to a reputable shop and someone I know. The tranny guy said it would wear it out a little sooner since it shifts stiff but I don't care since they're so cheap to rebuild. I think a 12 bolt takes extra horses to spin as well. You really only need the 400 and 12 bolt if your running some serious power like 500+ or if your having trouble burning up trannies and diffs. I ain't no expert though so take what I say with a grain of salt.
#15 ·
If you move to a TH350, have a hardended sprag put in.
But with the new heads you should see a difference.
383 Speed-O-Motive stroker kit with Speed Demon 750, RPM intake,Proform HEI dist.MSD6a box,World Products Sportsman II heads, ported and polished with 2.02/1.60 valves,64cc,TRW forged pistons with 10.7:1 compression, Comp Xtreme 284 cam,Crane pushrods, Comp Cam 1.6 full roller rockers,ATI damper, 40 series Flowmasters, 4.11 gears with TH350 and Hughes 3000 stall.Powertrax NoSlip Locker
#17 ·
the short rod will rev just as high as a long rod ,it just put a LOT more stress on the piston skirts.if the motor wont rev anymore it'll one of many things; weak valve springs,heads too small,cam too small,bad exghaust system,just to name some of the bigger problems it could be. i just freshened my 408 and you can definately tell the short rods put alot of stress on the piston,they were scuffed pretty good on the skirts,but they are forged and i have a tendency of not letting it warm up before i get on it,which is a big no no (with forged pistons).
the air flow research would have been the best choice(195cc) for the street. these heads are AWSOME! the sportsman II are great IF they have at least a pocket pocket porting done. the exghaust side will pick up dramaticly! don't forget to drill the steam holes in the new heads or you'll have cooling problems. i hope it screams for ya!
don't go with a 350 tranny,you can make the inside bullet proof ,but the case WILL crack if your motor is making 430 lbs of torque or more. this is of corse talking about slicks hooking on the track,if your not going to hook up you have nothing to worry about. the faster the trans shifts(shift kits) the longer it will last! the reason is because the clutches have less time to slip. the u-joints and rearend will take a beating though with a shift kit,but who cares its all in fun! go with a 400 it doesn't take an extra 50 h.p. to turn it over a 350 ,maybe 15 h.p.. the extra strength is WELL worth it!!!!
#19 ·
I think the sportsman II heads canbe made to work very well, with mild porting especially in the exhaust port. I run a car with a 350 chevy engine that has some of the same parts as your car has 1 5/8 headers 750 carb. For a trans I use a glide,the car has never been run in the 1/4 just the 1/8 my best 60ft was a 1.50 my best et was a 7.04 at 97 mph this package is in a 86 camaro and man this ride rocks . by the way there is NO Nos on this car, and I owe a great deal of this performance to the sportsman II heads. I know their are better heads out there but for the money you are paying for this set sounds like a good buy to me. oh that 7.04 in the 1/8 equals about a 11.0's in the 1/4 mile, aint bad.
#20 ·
I have guys here that run over 550+ ft. lbs. of torque to TH350's, and they haven't had any problems with cases.Several high 10 to low 11 second cars with 468BB and NOS, and not one case yet. If they are done correctly, they will last quit some time.
383 Speed-O-Motive stroker kit with Holley 750DP, RPM intake,Proform HEI dist.MSD6a box,World Products Sportsman II heads, ported and polished with 2.02/1.60 valves,64cc,TRW forged pistons with 10.7:1 compression, Comp Xtreme 284 cam,Crane pushrods, Comp Cam 1.6 full roller rockers,ATI damper, 40 series Flowmasters, 4.11 gears with TH350 and Hughes 3000 stall.Powertrax NoSlip Locker
#22 ·
i'm glad these people haven't had any broken 350 THs ,but from what i'ne seen,heard,and read i wouldn't want to take a chance with my $500-$900. the 400 is proven to be near bullet proof and will take more punishment than the 350. i've got a 350 behind my 440 lbs small block,hope it holds for a while in the 4x4. it will be beefed up.
i'm not trying to be a prick,but if the internals are built right how does that affect the strength of the case.i would like to know or have some hints so i can do this to my tranny before i go through it,thanks.
[This message has been edited by sldhd (edited 05-04-2001).]
#23 ·
The case breaks just after the internals shrapnel and lock up...its not pretty
There used to be a guy running around here in a 85 chevy truck with a supposedly well built th350 behind a nasty 468bb...4200 pounds and high 11's on slicks...completely shredded the th350 after 3 passes...it may just have been the way it was built, I dont know, but I would bet that vehicle weight and brute torque had a lot to do with it. Heck, I just put a fresh th350 in my truck last year after shredding the old one with my little ol' 355...of course there was no telling how many miles was already on it...it was ugly though...filled a big coffee can up with shrapnel, so I had a hardened sprag race and a few other internal mods done to the new one.
By the way, I wouldnt worry about the trans...I remember reading somewhere years ago that it takes 40hp to turn a th350 and 60hp to turn a th400...there are easier and cheaper ways of getting that 20hp back.
77 Chevy Nova
