My Vintage Air Install Notes
70K views 34 replies 20 participants last post by  67CruiseMasterCamaro
I'm sure my installation will differ from other people's but I thought I'd throw what I learned up on the forum for posterity.
This was my first Vintage Air install so I'm a novice. The car is a 1967 non-AC convertible. The front clip was off for engine swap, etc. I took the dash all apart so that I could repaint it after cutting vents in, install new firewall pad, and other things.
A one-line summary: of each of my findings is provided below. A full discussion of each follows.
  • Can get parts for inner fender well install with factory A/C balls, etc. directly from VA
  • Factory control panel pots are great
  • ECU is different for non-AC and AC-cars
  • Control panel sticker is lame
  • Need to re calibrate levers after every battery disconnect
  • Need to do something to tighten up OEM center vent
  • Buy new A/C center dash panel for OEM look
  • Astroball vents come with reducers to fit VA duct hose
  • Hard to cut A/C vent holes well and vents don't' sit entirely flush
  • Photocopy templates
  • Don't use template for upper mounting holes in cowl
  • Used studs for upper cowl mount
  • Welded firewall mounting bolt to bracket for easier install
  • Careful not to break drain hose fitting
  • Paint forward facing silver bolts/riviets black
  • Heater box can be installed over "blanking plate" for better look
  • Stick-on foam on defroster vents needs to be moved so not seen
  • Heater hose pipes must be cut or replaced
  • Used a straight fitting for large A/C hose
  • Comes with way more fittings than you need
  • Made my own kickpanel vent "hat" to house hoses and speaker
  • Can cover hoses with factory A/C kick panel
  • Heater flow control valve solenoid gets hot when energized
  • Replaced A/C head and charge fittings to clear Hotchkiss Chassis Max Handlebars
  • Trimmed extra ears off compressor in order to clear valve covers and handlebars
  • Had to elongate a hole in bracket that mounts to water pump
  • Powdercoated mounting brackets
  • Binary switch not sufficient if using an electric fan
  • Glovebox is small
  • Paint on condensor/drier brackets is lame
I had a few goals for my installation (and my restoration in general). This was to be a resto-mod whereby new technology had to look stock. Therefore, I was adamant that I wanted no aftermarket controls or vents and I wanted to make the underhood installation look as tidy as possible.
There are other threads on the forum that helped me realize that others had already figured out how to install a VA system by routing the houses through the kickpanel, cowl, blower motor hole, and inner fender well instead of directly out the firewall bulkhead. This info helped me and pointed me to Frank at Prodigy Customs. He was familiar with what I wanted to do and was knowledgeable so I ordered my system from him. At the time I was under the impression that he had some custom bits that he'd provide in order to make this all work. I subsequently found out that everything is available directly from VA. As a side note, I'm not going to bash Frank (he seems popular and he did help me early on and I don't know what his situation is - he might be really busy or something) but I will say that he went completely dark on me a little bit after purchase. No return of e-mails or calls after one post-purchase exchange (more details later). It might just be that he didn't like me but that was my experience, for what it's worth.
Back to the parts... Here is what I purchased:
  • 961167 67-68 Camaro w/o AC Comp kit
  • 561167 67-68 Camaro w/o AC gen IV evap kit
  • 62566-VCE Plastic fresh air cap
  • 62565-VCE 64-72 Chevy/GTO kp fresh cap
  • 33137-VUI Grommet large
  • 493067-LCA 67-68 Camaro center louver asm
  • 49306-VCL Louver kit 67-68 Camaro wo AC OEM
  • 04808-VUA Compressor A/C SD-508 134
  • 15126-SCA SBC SP PS Comp brkt
  • 547001 Extended length hose kit wo drier
  • 021067 67-68 Camaro w/wo AC cond w/dr
Truth be told there are a few parts there that I didn't end up using, such as the fresh air caps. And I probably could've ordered the compressor with the proper head and fittings for my installation but more on that later. The key to that list is that it includes the OEM-style center vent and astroball vents, as well as the extra hose and fittings necessary to run the install through the fender.
Another thing to point out is that the Gen IV Evap Kit includes the VA OEM Control Panel Conversion Kit (p/n 475168 for non-AC cars), which is a set of slide pots and wiring that allow the mechanical factory heater control levers to control the new electronic VA ECU for fan, temperature, and diverter. This is a great idea and it works wonderfully. The old levers move like butter compared to when they were attached to rusty old cables and it looks 100% stock. The conversion isn't difficult but it is worth pointing out that your existing controls need to be in operating order. The factory control assembly is made from cheap pot metal and breaks easily. When I pulled mine out of the dash I discovered that a previous owner had fashioned a make-shift repair where mine had broken. This discovery prompted me to consider purchasing a repro AC-style control panel to really complete the OEM look and I called Frank at Prodigy to discuss this. At this point in our relationship, Frank returned my call and, after some difficulty dealing with VA, he was able to convince VA to approve exchange of my non-AC ECU for an AC ECU. It turns out that they are different so order accordingly. If you plan to install the system into a non-AC car but use an OEM AC control panel then you probably need to tell them so you get the proper ECU. In the end, however, I was able to source an intact used non-AC heater control from a friend for very little money so I didn't end up doing the ECU exchange. For what it's worth, I tried to notify Frank of this (as well as ask further questions later) but was never able to reach him again.
The only lame thing about the VA control conversion kit is how they attempt to re label the panel. They give you a sticker that you're supposed to apply over the OEM panel. This requires additional disassembly (bending pot metal tabs that break and then require screws to reattach) and IMHO looks like crap. It isn't transparent for proper nighttime illumination and it has a "VintageAir" logo in the center. I didn't deem it worthwhile since it ruins the OEM look and the only benefit it provides is renaming the lowest "Off/Defroster/De-Ice" lever to "DASH/FLR/DEF" (the Fan and Temp levers don't change functionality) so I left mine alone. One other thing to point out about the OEM control conversion setup is that the potentiometers need to be re calibrated every time the battery is disconnected (or power to the VA evap ECU is lost). This is easy enough (levers to off, key on, levers to full, ground a little "programming lead" on the evap unit, wait a couple secs, key off) but you need to keep access to the programming lead handy and remember to do it.
Next on the OEM front is the vents. The gen IV kit comes with two round vents and a rectangular center vent and they expect you to drill your dash for the round ones and cut the dash and decorative center dash panel for their aftermarket vents, This is simple and economical but not the look I was striving for. IMHO, the outer round vents aren't horrible but the center vent looks like crap. It's too small for the space and just looks aftermarket. There is no way that I would ever consider not using the OEM center vent. It is available and, when used with a new AC-style center dash decorative panel, looks very factory installed. The only caveat to the OEM center vent is that it comes in two pieces that aren't held together in any way. It also includes two notched rubber pieces that are necessary to tighten up the rotating vent portion and prevent rattling. The trick is to figure out how to get it all assembled into one tight unit. The piece that a factory installation uses behind the vent is not a part of the VA kit. It just includes a plastic vent adaptor that allows connection of the round duct to the rectangular vent. I ended up using 3M weatherstrip adhesive to glue the rubber pieces to the side of the OEM vent assembly and fashioned two brackets out of aluminum that forced them down and to the sides to hold the rotating portion in place. This worked well on the workbench and allowed the adhesive to bound really well but I later discovered that they interfered with proper installation of the vent assy into the dash so I eventually had to remove my brackets. Fortunately, by then the notched rubber bits where securely attached and the vent rotates with perfect friction and no rattles. While the OEM center vent is a no brainer to me, the outer "astro ball" vents are a lot harder to install than the simpler aftermarket vents supplied by VA. You can install the aftermarket vents by just using a holesaw but the OEM vents require cutting more complex-shaped holes in the dash. And there is very little margin for error. Very little. The OEM dash bezels have very small (maybe a sixteenth of an inch) lip around the sides where they sit on the dash. Add that precision to the fact that the dash is curved, the hole is oval, and the bezel only fits flush if positioned absolutely perfectly on the dash and you have a real challenge on your hands. I can't profess to knowing the best approach. I used a drill, a nibbler, a pneumatic jigsaw, a Dremel, files, etc. and didn't get it perfect. While I didn't cut too big (thank goodness), I find that the vent bezels don't fit perfectly flush with the dash. This was exacerbated by the fact that the plastic chrome finish extends to the portion of the vent that is behind the dash and reflected any light visible in the gap. Therefore I painted the behind-the-dash portion of the vent flat black and the result is acceptable. By the way, the astroballs provided by VA have reducers that adapt them to the hose size used by the VA unit. One other tip: don't cut the templates out of the manual directly. Photocopy the pages first (making sure that you get a 100% size copy) and cut the copies. You might need to use more than one because they are tough to position properly on the dash the first time.
Speaking of templates, let's move on to mounting the evaporator under the dash. The unit is held by one bolt through the firewall where one of the heater box bolts used to be and a bracket that screws into the cowl near the right-side wiper arm area. They provide a template for where to drill the holes for the cowl bracket. This template indexes off the radio support bracket. Don't use it. I did and the holes ended up being half an inch offset from where I needed them and I felt like an idiot with two new holes in my cowl. Instead of using the template, just attach the bracket to the evap, install it under the dash with the bolt through the firewall, level the unit and hold it place while you mark where the cowl bracket actually meets the cowl. In other words, use the actual unit and bracket as the template. While mentioning this, let me point out that I had the evap in and out many, many times for test fittings, hose routings, firewall
pad replacement, etc. When moving the evap unit around, be careful of the drain elbow on the bottom of the unit. It is only glued on and breaks off easily. I had to epoxy mine back on. Also, note that some of the hardware (bolts/rivets/washers) on the front side of the evap unit is silver. You end up seeing a pretty good portion of the front of the evap under the dash. Take the time to mask and spray those bits satin black. Back to the cowl mount... because I now had two unwanted holes, and had already painted my exterior cowl so didn't want to weld them up, I welded two 10-28 button head bolts to a small strip of metal and dropped in into the properly drilled holes from the outside of the cowl, with some body gap caulk underneath. This solved two issues. First, the strip of metal covered and sealed the extra holes. Second, it allowed me to more easily and repeatedly secure the evap in place using two nuts instead of screws. Speaking of making it easier to secure the evap unit, I also tack welded the firewall bolt to the bracket on the evap unit so that I didn't have to hold a wrench to it under the dash. This made mounting the evap a one-man job.
To complete my OEM look, I filled in the holes where the heater core hose fittings came through the firewall and then reinstalled the heater box over the hole in the dash. You can only do this if you're routing the hoses through the kickpanel and cowl because the "normal" VA install uses a bulkhead mounted to the heater core area block-off plate. Speaking of which, if you are routing through the kick panel, you might want to weld a plate over the large hole in the block off plate since you won't be routing anything through it. I also mounted my MSD DIgital 6 Plus onto that plate and covered it with the (vented) heater box but that's an extra customization unique to my installation.
One small issue, the factory defroster vent piece gets replaced by two small, fairly cheap, defroster vent ducts that are mounted via a single screw to the cowl. I found that no matter how I placed them, the stick-on foam that seals them to the dash was visible on one end or the other of each so I had to replace it with new foam that was stuck on a bit further out on each edge.
Part 2. Back to the evap unit and house routing. Let me first say that the bulkhead install that VA recommends is easier, more serviceable, and probably better in every way except aesthetically. Routing the hoses through the kick panel is a huge pain in the butt and makes everything harder to reach later. That said, let's press on... The pipes and fittings provided in the kit bend at 90 degrees so that they come out the firewall where the heater core used to be, To get them through the kick panel you need to send the straight to the right. This means that you either need new pipes for the heater hoses or you need to modify the ones in the kit. The pipes are aluminum with o-ringed fittings where they attach to the evap's heater core. I ended up just cutting my pipes down so that they came straight out to the right of the car. This meant losing the hump flare at the end of the pipe but the heater hoses fit snug enough that they don't leak, especially when clamped. For the A/C hoses, I was able to use some of the many extra fittings in the kit to route them. The smaller, low pressure hose used a 90 degree elbow to get it pointing to the right side of the car and the larger high pressure hose used a straight fitting because it was already pointing that way. This meant ditching the complex insulated pipe that was provided to get the high pressure hose out to the firewall and meant using some of the provided insulating tape around the straight fitting to prevent sweating.
With the hoses pointed towards the kick panel, the next challenge is to get them into the cowl, while still sealing the interior of the car off from water. The kit comes with a plastic cap that fits into the oval vent hole in the body behind the kick panel. This cap has four holes for the four hoses and grommets to seal them. This would've worked fine but I wanted to get fancy and mount a kick panel speaker also so I made my own cap out of that was deeper (to allow the speaker to fit) and mounted the hoses higher up (above the speaker). I made a mold core out of shapable foam and made the cap out of fiberglass over that. I also made one for the left side to protect that speaker from the elements and seal the vent hole off. This was a lot of work and isn't ideal because everything gets pretty cramped and the speaker doesn't get a clear sonic shot into the interior when covered by the factory A/C bulge panel but it was a reasonable compromise for my efforts at a stock look. From the kick panel area, the hoses turn up and forward out the blower motor hole. The kit includes a round plastic cap with four more holes and grommets to install over the blower motor hole in the firewall. You can use it if you want but I didn't. There's no point in sealing that hole because the cowl is open to water from the wiper area anyway. I don't think the plastic cap would offer much in the way of heat barrier and I was installing the heater box (sans blower) over the whole area anyway. I protected the edge of both the firewall hole and the heater box hole with windlace trim and let the holes open. I also ran my wiring through that area, into the inner fender liner. Also in that area is the heater flow control valve. It will be a bitch to service if it ever fails and I noticed that it gets really hot when the solenoid is energized, which is when the temp lever is pulled to full cold. I called VA about this and they agreed that it gets hot but said it wasn't an issue and you shouldn't be on full cold that often anyway. I didn't love that answer but it was useful to know, because now I don't leave the temp lever fully to the left anymore, even with the fan is off.
Once everything was routed, I covered it with the factory AC style kick panel and factory AC bulge panel to hide the hoses and speaker and provide a stock look. Both panels had to be modified to allow installation and clear the evap unit.
Under the hood, I had some issues mounting the compressor. I have headers and the bracket kit comes with spacers for 1/4" and 3/8" flange headers, as well as exhaust manifolds but I found that needed to relieve the hole in one bracket where it mounts to the water pump in order to get everything to fit. I also powdercoated the brackets because they come in bare steel. My installation was further complicated by the fact that I have roller rockers with taller valve covers and Hotchkiss Chassis Max Handlebars. The ears on the compressor hit both the valve covers and the handlebars and the fittings on the back of the compressor came up right where the handlebar crossbar is. There was no possible way to turn the compressor to get clearance so I had to buy a new compressor head and fittings from Nostalgic Air Parts in order to run the hoses straight back. This worked like a charm and the parts were very reasonably priced. They even have install videos. I probably could've order the compressor with the proper head and fittings had I known. To complete my installation, I cut the unnecessary ears off the compressor and cleaned them up with a file, grinder, etc.
Installation of the condenser and drier was straight-forward enough but I repainted all the brackets and bolts because the flat black paint they ship with scratches easily. I also found that it was better to mount the drier with some bolts and nuts instead of the provided sheet metal screws.
When everything was done I had to pay an A/C shop to crimp the final hose fittings while on the car (some of the fittings I was able to do at the local parts hop with the hoses off the car). They also evacuated and charged the system. Note that the parts (evap, cond, drier) all come sealed and charged with dry nitrogen. You're going to have to open them up in order to install the parts and you're probably not going to finish everything in a day or two, unless this is all you're doing, so you need to make sure that you plug any fittings or hoses to prevent moisture from getting into the system. It takes 1.8 pounds of 134a and we found one last issue after charging. The system ships with a binary pressure switch on the drier that prevents the compressor from working if there isn't enough pressure in the system or is too much pressure (more than 406psi) but if you use an electric fan like I do then you need to use a trinary switch instead. Without this, the pressure builds excessively when the A/C is on but the engine temp is below the electric fan switch's threshold. The trinary switch is wired into the fan relay circuit and turns the fan on whenever the A/C compressor is on (in addition to providing the same compressor pressure safety).
Final observations are that the system is quite nice and modern. I'd say that some of the parts provided, such as the binary switch and some brackets are a bit on the economical side but with a little fabrication you can make the system work and look quite good. It's nice to get heat out of the dash in the convertible right now (temps here in SoCal are down into the high 50s) but I haven't had a need to really test the effectiveness of the A/C yet. It sure blows cold in this weather though. The controls work great. The system looks pretty tidy under the dash and under the hood. Now that it's installed, the only downside is a loss of glovebox capacity.
Great write up. I am a firebird owner, but most everything is the same. I have one question and have a request for most pics. I am doing mine the same way as you running lines through the fender. Did you receive long enough hoses from VA or did you get those some where else? I purchased my kit through matt at classic bowties. Mine didn't come with hoses that were long enough so I will have to either talk to VA to get things squared away or come up with them on my own.
Secondly, can you post some pictures of the hoses in your engine compartment? I am looking for suggestions on how to route them. It looks like you might have went straight from the opening to the water pump for the heater hoses. Did the other two come out near the battery? Thanks for the input. It is always great getting someone elses perspective rather then the good old trial and error method.
#6 · (Edited)
Hey guys, I'm running my AC lines through the blower motor hole like Jeff did. To get it to work with the Screamin' Performance kick panels I needed to use a 2 single bulkheads. What do you think would be the best way to seal the bulkhead against the car sheet metal. 3M strip caullk, silicone, rubber washer, etc. The hole I drilled fits the bulkhead nice and tight but I still need to seal it with something that will last, since this is in a wet area of the cowl. Also, not sure how hot the number 10 and 6 lines get going the Vintage Air unit. Thanks for any help you can offer.
If you have a unit that does not allow for the bulk head routing like I did I used some brass 90's and routed the heater hose trough the bulk head and the A/C trough the stock heater box. I bought my vintage air unit about 5 years before it was actually installed, if I would have known I would have ordered one like you did. The plastic part that goes on the firewall is just complete junk and looks horrible!!
These pics are how I did mine. I post these for people that might be stuck.....Like I was.
I had to split the gromment a valve cover oil fill grommet, after it was installed all the way I just used some dum dum around the hose and the grommet
Thanks Joe for the pictures. I'm doing basically the same set up you have except I'm putting the heater hoses where they would come out for a factory big block car and running the AC lines through the blower motor hole. I wounder what is the best way to seal the bulk head I'm installing? Sure would hate for this to leak once the car is back together. It would be a real pain in the #&% to fix.
Thanks,
Wish I could be some help. What sucks is there are a number of ways to mount a route hoses and for me the tech help at vintage air was totally useless. They told me about "extra" parts I could buy and extra mods I could make to the system but they would not tell me what to order for what I wanted to accomplish. In all fairness in the 2007 time frame when I ordered my set up (installed in 2011) the "other" AC guys/supplier could not tell me much eighter. I think the gen Iv stuff is much better not sure about customer service.
#12 ·
Thanks for the info,great ideas.
I am installing a VA kit in my 69 ls1 now.
I hada problem with the condensor hose going to the drivers side for a older style system. A call to VA answers my problem fast and I am running theh ose from the pump to the condensor all I need was a 90 fitting that should have cam extra with the kit or free but oh well.
the other problem is I asked for the firewall hoses to be routed inside the fender and they do not.. but after mock up and shaving the firewall I decided it would look just as clean to run the hoses straight along the fendewell and might be easy to do maintance later on if needed.
Off topic but did the kick panel speakers fit in the stock kick panels?
#17 ·
I would like to share an install tip with all if you are running MSD ignition do not run any of the wires near each other both the wires 12volt coming to the MSD and wires out of the MSD the vintage air will turn on and off heater valve will click blower will cut on and off with car running and ac off. a few wireing notes would have been nice.
How I ran my hoses on my 69Z. I did use premolded heater hoses to run from the heater core out directly to the engine ports.
I used a factory OEM center port and had to change out my non ac dash to an factory ac pad. Used the stock Astro vents for side AC ports.
#19 ·
Jeflit,
If you are still reading TC (this is an old post), or anyone else that might know...
The #6 size line is a hardline on my kit. in order to route it behind the fender I changed it to a rubber line...I hope this is okay....?
Anyone else do this too or have a kit where all four hoses are rubber?
This has been a difficult install and it appears that vintage air forgot three parts in my order--it has cost me many hours and much $$ to replace...
Thanks,
Brent
#21 ·
This is on my near term list... I ordered the system several years ago, just getting around to the install now.
I ordered the extended hose kit which allows you to route up under the fender and through the blower motor hole.
Might get to it this week...will let you know.
Jim
#23 ·
I have the original kit that came with my first order that has a plate that covers the large opening on the firewall. That has a set of hoses and connectors with it.
2wks ago I ordered the "extended" kit, and it came with the circular cover with 4 holes in it that routes through the blower hole. I haven't looked at the length of the hoses yet.
Did you buy a crimping tool for the ends?
Jim
#24 ·
A bit of venting:
My order did not arrive with all the pieces.
It is missing the hard line to the top of the condensor and the entire fender wall install kit.
it cost me probably 15 hours of exta work and $116 for new hoses to replace the 48" hoses they sent by mistake.
I have about 25 hours in the install so far because of all the unexpected things I encountered and I still need to wire it, connect the vent hoses, and change my water pump and crank pulleys (why do I have to do this?)
I had no idea that I needed a specific alternator, power steering pump and water pump pulley. i have a normal vortec head 383--I have no idea why I needed all new accessories to match the brackets VA sent me. I have a ton of money beyond the cost of the "SureFit" kit. \
The power steering pump needs to have two attachment points on the rear (mine did not), the alternator has to be a specific spacing between the two ears (my brand new one was not). My water pump pulley is single groove, Alan Grove says I have to have a double groove, but it needs to be GM because "after market pulleys do not line up" (but they have no idea which one I need to get).
I still have another 7 to 10 hours to go in the install...I wish I knew why so much of the install was not straight forward...and I have no idea what else will pop up as I try to finish it and use it...:(
#26 ·
BrentMC,
Reading your post makes me glad I spent the money on their Front Runner serpentine kit. By pure luck, I avoided the pully/accessory issues you outline above.
25hrs and a bunch of extra costs...that's not what anyone signs up for.
When I received my blower-hole hose kit, I had no idea that the hoses would not be terminated, so that adds another "step" to the list. The required crimper isn't cheap. I didn't have access to my car at the time, so I sent them an email asking if the hoses would pass through the blower hole plate after they've been terminated, figuring that if they do, I could take the lines to a shop and have them crimp on the fittings.
Their response was "Call us...", so not sure what that means. Seemed like a simple enough question.
Jim
#28 ·
Jim,
They don't mention the fact that the hoses need to be cut and then taken to NAPA to be crimped (more time and money)
The holes in the blower cap are fine for the heater hoses (they have no fittings); for the pressure lines, the fitting is near 90 degrees and I think it would be pretty hard to get them through the hole.
If the case, you will need to take the hoses already inserted into the blower hole cover and have them crimped. Not a huge deal, just more time consuming and another surprise time eater.
I have identified the right water pump and crank pulleys--no I just need to find them (they were on a bunch of mid-70's to mid-80's cars, but I need to find them)
I just bent my knee backwards skiing and will be out of commission for awhile, so AC will remain undone for awhile.
#27 ·
Bit of an updated for me:
Living in Arizona I have yet to get my Vintage air system charged and going I have been working on other items first. I have put about 5K miles on the 67 since moving here and getting it running. I went through last summers cruises and shows with no A/C, it was not really to much of a big deal. After all I have lived with the 67 for many years and many miles with no A/C.
After being through my second winters here I have just eliminated the heater hoses all together!! I have yet to have a time where I needed the heater. After I finish up my 700R4 conversion I may start on getting the A/C wired up and charged to see how it goes. I hardly use the heat in my FJ Cruiser unless I am out 4 Wheeling it....LOL!!!
#29 ·
i realize this post is a bit old... i'm starting the install of this on my 1967 RS, and am sure i will need, or want, to customize it a bit. one thing i can't find info on is: do i need new kick panels with this install? i realize now that i'll be losing my fresh air intake, so the handles are irrelevant once it's done, but, do i need anything special when i replace the kick panels?
thanks!
ron
#30 ·
Many folks recommend the 'Screaming Performance' units - http://screaminperformance.com/camaro_kick_panels.htm
Here's a past ProTouring thread about them - http://www.pro-touring.com/threads/57006-Custom-kick-panel-for-1st-gen-Camaros
And a TC thread discussion - http://www.camaros.net/forums/showthread.php?t=191673&highlight=Kick+panel+speakers
I purchased a set a few years back for a AC installation project I was asked to assist in completing and they fit very well with min. modification to fit our application.
I did not install the speakers, an audio shop did those, just did mock-up for them and then installed the rest of the ac system ...
You might also want to open a new thread once you've explored options to get fresh info from others and leave working links behind for others to use :cool:
#31 ·
Glad to see this post still alive and actually helping out people. It's not sure fit system for sure if you have any modifications at all.....which is understandable. As I stated in my last post back in March of 2014 I eliminated my heater hoses.....living in Arizona allows that. In june or July of 2014 I went to work charging the system. The first order was sucking it down and finding leaks. A few were found so it was off to Harbor Freight for a purchase of their A/C o-ring kit for $10.00. I also bought 4 cans of 134A at Home Depot for $8.00 for each can. A friend had some charging adaptors and gauges along with a vacuum pump to suck it down. I also bought a little bottle of pag oil to lube the o-rings. I replaced all my old o-rings with new ones. We sucked it down and found one leak. Fixed that and now more than a year later my A/C blows ice cold.
In the Arizona heat I drive with my windows down and the A/C blowing and it keeps me cool and I also have the fresh air wind blowing through the car. Roll up the windows and it keeps the 67 as cool as new car A/C system in our new cars, maybe colder!!!!
I also routed all my electrical through a conduit and out my kick panel, through the drain and up the firewall toe kick and behind the fender and to the front of the car. Very happy with how the system works and how it looks after being done. I always have people ask about the system the firewall pass through in the stock heater box that i did and wonder who made the system. Have to tell them it's custom job and they will have to improvise and figure out what to do if they want to escape the dreaded plastic firewall plate.
#32 ·
Vintage and Joe, thanks for the quick responses - and sorry for my delay in saying so. i appreciate the info. those kick panels are nice! those may work out perfectly because i have a set of 6" speakers that i needed a spot for.
i have the condenser hung and the compressor mounted (billet specialties serpentine setup) but am trying to find the time to get the rest done... snowball effect = i'm going to insulate the entire cabin, and clean up some wiring when i do the interior portion of this. have TMI front upholstery since the seats are coming out. freshening up the engine bay and adding in some modern toys as well - radiator, already mentioned the pulleys. oh yeah, there's a baby due in two weeks also, so, can't promise this is going to be done during the summer months!
again, thanks for the information. i consulted this thread before i even purchased the VA setup to see what i was up against.
#34 ·
Oh, I have to post this, I know this is a very old post but hope this helps others:
during the install they have you seal off the kick panel vents, if you remove the slider that opens the flapper door you end up with a small hole where the cable went thru, you can install a latching push button switch ground to gray programing wire, this way to reprogram you push the button, reprogram, then push again to come out of program mode.
that’s the passenger side, for the driver side drop in a 10k ohm pot for your dimmer of a Dakota digital.
here’s some photos:
