I am starting a project to narrow a Impala 12 bolt for my 69 Camaro. It's not going to see any strip time so no C Clip eliminators, spools, etc. I am building in the vein of a COPO BE rear end. Sort of like the guys over at powernationtv.com did. I would like to use USA made parts as much as possible. I know Moser has the small bearing ends and spring perches so I'll order those.
If anyone could recommend parts and vendors you've had luck with I'd appreciate the advice.
My second question is has anyone used the 12 bolt narrowing bushing on EBAY from seller leadmineproducts? It looks like you get bushing for the caps and bearing ends, you supply a 1 1/4 bar to keep your ends straight when you weld them back on. If anyone has had luck with something like this let me know. Thank you in advance. Brent.
