Pitman Install- is this enough?
3.7K views 14 replies 11 participants last post by  norcal_68
I am installing a new pitman arm on a new steering gear. I read a post from David Pozzi that the arm does not need to be sitting all the way against the steering gear. I'm wondering if this is enough. It's becoming very difficult to turn the nut and I don't want to pull the threads out.
All help is appreciated.
The splines on the pitman shaft are tapered. So the arm will be perfectly safe even though you can see some pitman shaft splines between the arm and the gear housing.
The fact that you have several threads from the pitman shaft sticking out past the nut proves that you are in the ballpark.
However, the torque spec is 180 ft-lbs. You most likely will need an extension on your torque wrench to be able to reach that correct figure.
Jim
#11 ·
Be sure to torque it with pitman arm rigged up against a piece of 2 X 4 wood between the end of the arm and the frame. That way you don't strain the internals of the steering box.
#12 ·
I'll have to check mine when I get home, but recall that the arm can only go on the splined shaft in one position - one of the splines is wider to form a keyway. As long as it's properly aligned, torque away.
