When you first set the choke on a cold motor, the choke slamms all the way shut. The "pull off" is a vacuum solenoid that should open the choke blades 1/8" as soon as the motor starts.
Until the choke is open all the way, a linkage locks out the secondaries. Nothing to do with the pull off, but it is there.
Generally, q-jets bog if the secondaies open too fast. Not opening at all the car would be down on power, but still run pretty well.
Search out a "book" on q-jets, they are on the web. Study up a bit, then watch the carb. Is the choke linkage adjusted properly? Is the choke opening all the way as the motor warms?
The secondaries have both a mechanical progressive throttle plate (low in the carb, connected to the primaries with a linkage) and a spring loaded air valve (you see that one on top.) The air valve is adjustable so it doesn't open too fast. You can hold the choke open and manually work the throttle, you should see the linkage opening the secondary throttle, and lifting the needle hanger which is between the secondary bores at the top of the carb.
