Sniper EFI/Hyperspark Component Location
466 views 9 replies 5 participants last post by  tp_smith
#1 · (Edited)
For everyone who installed the Sniper EFI and added the Hyperspark Ignition components, where did you install everything?
I got the Sniper 2 system and all hyperspark components for my 69 Camaro, and it seems easy enough to install, but I'm getting "analysis paralysis" trying to find the best spots to install/mount some of the components, specifically the Ignition module, Coil pack, and PDM. Just wondering where everyone else has put these things.
I appreciate any ideas/suggestions that you all have. Holley mentioned that these components can be inside the cabin too, nothing necessarily has to be under the hood. I'm also considering relocating the battery to the trunk so I can use that spot in the front for some of the hardware, the previous owner had it that way so I already have all the parts to do that.
I like to install the Hyperspark modules in the cowl. This gives them a Faraday cage of sorts to keep their spurious radiation away from other sensitive components. Some sort of splash shield is usually needed.
Reactions: rxc224
