It aint starting.
I tried last week, and as soon as the fuel pump kicked on, the engine rumbled and chuged for about 15 seconds. I had to shut it down to fix a fuel leak at the regulator. Today I'm back at it.
It's a stock (inside) ZZ502
-Edlebrock Perf Airgap
-Edelbrock Performer carb (reconditioned from my old engine)
-Pertronics Igniter II distributor (red wire to coil+ and black to coil -)
-Pertronics Flamethrower coil (I remove the resistor wire and jumped an ign hot wire to the coil + side from my Painless Perf aux fuse panel. I left that yellow wire that was bundled with the resistor wire off the coil also...I think it's the same one that goes to the starter, but the other end is not used by my Hitachi minstarter anyway.
-With the Ignition switch on, the coil gets about 11.90 V
- Wife says the fuel gage at my carb reads 6psi while I crank. It's a Holley Blue electric fuel pump.
-I installed the distributor with the engine rotated to 12deg before TDC. I pointed the rotor directly at #1 terminal....it moved a little while installing plug wires...but it's in the ball park.
- I poured a little gas down the carb to see if that'd at least make it chug again....nuttin'
Any ideas?
Any ideas?
