I got my car finally timed, the total timing is at 32* there is no more detonation, the only thing is when you shut her off she runs on, do you think its running on because its running to rich? And also when I was timing it I plugged the vacuum advanced but as soon as I reconnected the vacuum line to the distributor the RPM jump to 1500RPM in park and when you put into drive they drop to 900RPM, so currently I have the vacuum plugged and in park its at 700RPM and in drive drops to 600RPM which is how it should be, how do I fix this?
