Gee, golly, so hard to go to Google and look there, too much work, too confusing.
One point, NOBODY is forcing anyone to do it right, do it any way you wish, even at the bottom of the lake, if you so desire.
So, OK, lets go over a couple of things.
As we are all aware, a hot engine cools off, and as it does, so clearances change, as in valve clearances. But, trying to set all 16 valves as the engine is cooling off, DOESN'T GET THE ADJUSTMENTS ON THE LAST FEW VALVES CORRECT, as the engine has significantly cooled.
Hot engines also have another great trait, THEY BURN HANDS,
Now, IF the engine is cold, as in overnight, no hands burned, and, ALL valves get adjusted to a uniform spec, EVEN WHEN YOU MAKE YOUR OWN CREATE A SPEC TO DO SO
And getting to what "E-O, I-C" means, is one of those dangedest hard things some just cannot understand, or, closer, refuse to even read, and learn, so......
Setting valves, engine cold, with Create A Spec, (And, I hope the other post was read, because here is where you need to know your COLD SPECS).
ONE PAIR OF VALVES, FOR ONE CYLINDER AT A TIME, HAND rotate the engine in the normal direction of rotation by socket and bar, from the front pulley set, until
The exhaust on the valve set is just opening (or, the push rod just starts to rise).... SET THAT INTAKE VALVE,
HAND rotate the engine to open, close that exhaust, and do the same for that intake valve
As the intake valve you just set, fully closes
SET THAT EXHAUST VALVE
Then, go on to the next pair of valves for another cylinder, repeat.
When done correctly, each valve only needs to be set ONCE< not 40 times hot, to get the right clearances.
It is just that easy, just that simple....... PAY ATTENTION, DO IT RIGHT.
Now, are any of you missing just why you created a cold valve clearance setting, and doing the adjustments, WITH A COLD ENGINE, over a hot one???????????
