What could cause upper control arm bump stops to get damaged?
1.6K views 8 replies 6 participants last post by  fairfax1000
I installed new stops when installing new coil springs, shocks, balljoints, etc not very long ago. I found this one in driveway yesterday, and checked to find the other one is missing as well. The small end that goes thru hole to hold them in place is still there; just looks like they got smashed & broke off.
This is what they looked like when I installed; and again, the small end is still in the upper arm hole….strange
Those are going to be a bit of a bear to install on the car. I suspect they failed when the car was on a a lift or a jack with the suspension fully dropped.
If your ride height is not high you can likely get away without them.
Don
Reactions: Vega$69
