What kind of heads are these?
1 reading
19K views 5 replies 3 participants last post by  Doug Garland
My friend just gave me a set of heads that he said were off a small block 400 the numbers on them are 3832441 does anyone know about these?
70 1/2 RS Camaro
Are you sure that's not 3932441. The 3932441 heads are 1969 350/250,255 hp heads (Pass, Chevelle, Camaro,Chevy II) 1.94 intake/ 1.50 exhaust with 76.26 cc comb. chamber. This head was also used in 1970. The casting symbol is a rectagular shape. These heads are very sinilar to the camel hump heads used on the 69 300 hp vettes.
I'm not that familiar with small block chevys ( I'm into bb) but from what i've read these seem to be basically the same castings as the famed camel or fuelie heads except for a slight cumbustion chamber reconfiguration. I guess if you match them up with the right set of piston you could have a good combo. Basically, the same heads with 2.02/1.60 valves were used on the 69"" 300, 360, 370, 350 ci inch small blocks in 69.
