Which Muncie - M20 or M21?
5.5K views 12 replies 8 participants last post by  keithl1967
I'm plan on putting a 4 speed in my 69 and I'm confused on which Muncie to choose between the M20 & M21. I have a BB 402 and plan on running 3:42 or 3:73 gears. Can someone explain which tranny would be best for my setup. I'm able to purchase either one. Thanks,
Clint
Clint,
What will you be using your car for? Mostly a street car, drag or road racing?
Here's the ratio difference:
M-20: 1st 2.52, 2nd 1.88, 3rd 1.46, 4th direct drive
M-21: 1st 2.20, 2nd 1.64, 3rd 1.28, 4th direct drive
If you go with 3.42 rear end gears, I'd use the M-20. M-21 would be better suited for lower gears like the 3.73's you're considering. When I bought my Camaro in 89' it had a M-21 with 3.08 rear gears and was a dog off the line.
The tooth count on the close-ratio M-21 makes it slightly stronger, but the wide ratio M-20 provides more torque multiplication.
M-21's were typically installed on cars with 3.73 rear gear or higher (numerically). If you run the 3.42's go with the M-20.
In fact, I would go with the M-20 with the 3.73's. The engines we build today have a much greater useable RPM range, and the need for close ratio stuff isn't as necessary.
If you're looking for a very sturdy Muncie or Muncie parts, including the SuperCase, here's a good place to call:
www.autogear.net
FWIW
M20 on the street do to the 1st gear ratio.
Jody,
It should be a mild build but I'm hoping to get around 375 - 400 hp out of it. I just had the block bored .020" over and using Keith Black HP 160 pistons, heads are cast iron #3964290 and using a Comp Cam XE268H cam kit, Edelbrock Performer RPM, 750 Holley, and Headers. Any ideas where I might be with this combo?
Thanks everyone for your help,
Clint
#11 ·
Sorry Clint, didnt mean to hijack your thread. Maybe this will help with your decission before you spend the money. Maybe your car will be better in 1st being a BB having the extra torque and a smaller cam?
Jody,
Can i just change out 1st gear in my current m-20, i just took out a Saginaw and the m-20 was totally rebuilt already have $1,100.00 in it:(
