I have a 67’ with a rebuilt 350. The cam is a pretty lumpy comp cam and the car progressively started running, starting rough and I was hearing ticking from under the valve covers . I noticed a spark plug cable on backwards which was no big deal, but when I removed the vacuum advance hose off the distributor, I noticed the distributor was loose. It was probably out around 10 degrees advanced. I rotated the distributor back to where the engine ran great and tightened the clamp down. I know I need to get a timing light.
Now that the distributor is back where the engine runs great again, I hear what I recognize from past vehicles as a timing chain rattle when I accelerate at the bottom of a gear (5 speed) but I’m not sure if that’s what it is. There is still a slight ticking coming from under the valve covers. Did the loose distributor cause damage to my lifters/rods. What could I look for? Thanks for the help!
