69 camaro budget fuel tank
6.7K views 18 replies 12 participants last post by  X-77 keith
Just wondering if there any cheap reliable options for a fuel tank im doing an l99/6l80e swap and i bumped into a post from a guy who did a 1994 caprice fuel tank swap on his first gen he swapped the pump for a walbro 255 just wondering if this would be a a good swap let me know thanks.
Tanks Inc. hands down ... don't even bother wasting your time and $$$
Inexpensive, fits perfect and works 1000% perfectly
Cheers
Steve
Reactions: DT
#12 · (Edited)
Where are you getting a tank that fits your car for $30?
How is the Walbro pump installed in the $30 tank?
Just drilling a hole in your stock sending unit doesn’t work as the return fuel squirting into the tank wil aerate the fuel in the tank. The return line should extend to the bottom of the tank.
You can use an external pump and bypass regulator along with a dual line sending unit.
??? .... E, $500 gets you almost everything you need for your entire fuel system
Also consider this E, your building a 69' Camaro ... these are always a valuable commodity 'IF' you do them right. This doest mean you have to make it a $100k pro touring car, BUT If you start mashing parts together from different vehicles the value of your car will drop like a stone ... just something to consider
Cheers
Steve
I'd like to see a picture of how well that fit under the car.
I know people do LS swaps on the "cheap" with junkyard pull out drive trains, But I thought the Tanks Inc. setup was still getting off cheap when doing an LS swap.
#13 ·
Just because their 'inexpensive' doesn't mean that they are cheap ... remember its simply only a gas tank, guys that spend $1000's on a Stainless tank do so unnecessarily. I'm sure John will comment, we've sold BIG dollar Camaro's with Tanks Inc. systems and trust me 99.9% of buyers couldn't care less
Cheers
Steve
Rockauto sells the Spectra GM32BFI tank for $281 and that includes the fuel pump. Did a 69 LS1 swap last year and it's worked fine for over a year now. If you would feel more comfortable, you can swap the fuel pump for a better version but so far I've had zero issues with it.
Alex
#11 ·
You could just buy the external fuel pump kit I’m selling in the classifieds and drill a return in your sending unit and call it good.
#15 ·
I paid ~$230 for a Spectra GM32BFI tank when I installed the Gen 6 454 in my 69 that doesn't have a provision for a mechanical fuel pump. It works and looks excellent. It's $281 at Rock Auto right now.
#16 ·
The $30 tank was due to the 40% off sale at pick a part plus you would have to consider the cost of the walbro pump i didnt go through with it as i took into consideration everything that was mentioned and as everyone lets do it right the first time.......... i guess ill have to wait a few more years once again these LS swaps aint cheap but i guess ill be on the hunt on ebay for some decent bargains.
Thanks Guys!!!!
#19 ·
I just bought a Tanks. For my 66 el camino build. Its a no brainer to me. Got it from MCB.
