I dropped my fuel tank to replace it and bench tested my 47 year old sending unit, it reads 10 ohms empty and 110 ohms full at the pin.
At the resistor where the flat wire connects it read 5 ohms empty and 100 ohms full.
Obviously there is some resistance gained at the pin and resistance goes increasingly off as you move the wiper up to full.
I tried cleaning the contacts around the pin and it seemed to work but a day later the readings are off again. I thought about putting a 10 ohm resistor on the wire but it would still read high at full.
The only thing left is to open the resistor and try to fudge it into reading right but is it worth all the effort?
Or should I replace it now with the tank out and buy a spectra unit for $60?
