'69 Gas Gauge Location
889 views 14 replies 7 participants last post by  Bob Tiley
#1 · (Edited)
Where did GM land the 'gas gauge' in the dashboard when the pod to the right is the tach and the pod to the left is a the speedo?
#13 ·
Type "camaro research group" without the quotes into a google search. Then you should be able to follow the links. If you have an ad blocker or site blocker you may have to add the site to your safe list. One other problem I have had is CRG's url address is not an https address and some operating systems won't allow a site without it for security reasons. If that's the case with your system a message should pop up giving you a work around.
#15 ·
With the factory tach there were 2 options.
1) in the center gauge pod where the clock could also be installed if the car did not have a center console.
2) It is one of the 4 gauges on the console and a clock would be installed in the center of the large gauges.
As already stated, it is explained clearly at Camaro Research Group site.
