1,301 - 1,320 of 3,198 Posts
Mike,
Did not check to see if it is a V8 car. It was and automatic but comes with a 4 speed. I don't really care, it was a Frost Green/ Green Standard so it is a made up car. Looking for a BB for it and a 12 bolt. Get well and hope the nurse doesn't cause too much pain!!!!!
Discussion starter · #1,303 ·
Mike,
Thanks Bruce
Discussion starter · #1,305 ·
Discussion starter · #1,308 · (Edited)
Here is a list of correct part finishes for the 69 Z 28 from Jerry MacNeishes book " The Definitive 1969 Camaro Z28-SS 396 Fact Book"
PART FINISH
Air adjusting brace 67-68 60 percent gloss Black paint
Air anti backfire vavles Gold cadium dichromate
Air diverter vavle bracket 1968 60 percent gloss Black paint
Air pump muffler cover, 68-69 Flat black paint or black phosphate
Air pump support brace 67-68 Chevrolet Orange Paint
Air pump support brace 69 60 percent gloss Black paint
Air smog pump housing Natural aluminum finish
Air smog pump pulley Black paint, 60 percent gloss or grey phosphate
Air smog tubes Black paint, 60 percent gloss or Gold cadium dichromate
Air cleaner assembley, ZL2 ducted hood 60 percent gloss Black paint
Air cleaner base, open element 60 percent gloss Black paint
Air cleaner lid, open element standard 1967-69 Chrome
Alternator assembley Natural aluminum finish
Alternator pulley 67 Z28 silver cadium dichromate
Alternator pulley 68-69 Z28 silver cadium dichromate
Alternator fan 1967 Z28 Semi gloss black paint
Alternator fan 1968-69 Z28 Z28 silver cadium
Alternator brackets lower, 67-69, 302, 350, 396, 427 Black paint, 60 percent gloss
Alternator brackets upper 67-68 302 front Black paint, 60 percent gloss
Alternator brackets upper 67-68 302 rear Chevrolet Orange Paint
Alternator brackets upper 1969 302, 350, 396, 427 60 percent gloss Black paint
Alternator bracket spacer Black paint, 30-60 percent gloss
Battery hold down clamp Natural metal finish
Battery tray 30 percent gloss black paint
Bell housing Chevrolet Orange Paint
Bell crank, throttle linkage 30 percent gloss black paint
Brake hose bracket Natural metal finish or silver cadium dichromate
Brake lines Natural metal finish or stailess steel
Brake switch manifold Natural metal finish
Bumper brackets front & rear 60 percent gloss Black paint
Bumper jack base semi gloss grey paint
Bumper jack adapter semi gloss grey paint
Bumper jack mechanism semi gloss grey paint
Bumper jack pole gold or silver cadium dichromate
By pass elbow (water pump 67-68, 302) gold or silver cadium dichromate
Carburetor gold cadium dichromate
Clutch fork Natural metal finish
Clutch linkage semi gloss black or Natural metal finish
Coil bracket silver cadium dichromate
Column locking mechanism 30 percent gloss black paint
Control arms, front, upper and lower 30 percent gloss black paint
Control arm shafts upper 30 percent gloss black paint
Core support 30 percent gloss black paint
Cowl plenum air cleaner assembley 68-69 60 percent gloss black paint
Cylinder heads Chevrolet Orange Paint
Dashboard top 67-68 30 percent gloss paint
Dashboard top 69 Suede paint finish
Deck lid striker 67 all silver cadium dichromate
Deck lid striker 68-69 all painted body color
Dip Stick and tube Natural metal finish
Disc brake caliper mounting brackets 67-69 gold cadium dichromate
Disc brake backing plates silver cadium dichromate
Distributor Natural metal finish
Distributor hold down bracket Chevrolet Orange Paint or Natural metal finish
Door latch mechanism screws 67 silver cadium dichromate
Door latch mechanism screws 68-69 painted body color
Door striker 67 all silver cadium dichromate
Door striker 68-69 painted body color
Drive shaft Natural metal finish
Engine block Chevrolet Orange Paint
Engine lift hooks 302 Chevrolet Orange Paint
Engine lift hooks 396, 427 Chevrolet Orange or silver Paint
Engine vent tube 67 only 60 percent gloss black paint
Exhaust manifolds natural cast iron finish
Fan blade 60 percent gloss black paint
Fan clutch assembley silver, gold cadium dichromate or Natural metal finish
Fender bolts Black phosphate
Fender skirts 30 percent gloss paint
Firewall 30 percent gloss paint
Firewall stamps orange or green paint norwood cars only
Floor pans 30 percent gloss paint, with body color overspray
Flywheel shield Chevrolet Orange Paint
Front springs 67-69 Natural metal finish
Rear springs 67-69 Natural metal finish
Front cowl under cowl pannel body color to edge of firewall, line is not crisp, feathered
Front cowl panel retaining screws silver cadium dichromate
Front spindals Natural metal finish
Front sway bar mounting kit silver cadium dichromate
Gas lines Natural metal finish
Gas tank Natural metal finish galvanised
Gas tank straps Natural metal finish or 60 percent gloss black paint
Grill front 67 RS, SS, NON RS black
Grill front 68 RS, RS SS black with horizontal silverlines
Grill front 68 non RS painted argent silver with semi gloss black upper, lower section
Grill front 68 non rally SS black
Grill front 69 non rally sport argent silver paint
Grill front 69 rally sport black, black cars silver grill
Grill front 69 non rally sport SS black
Ground straps engine bay natural copper finish
Harmonic balancer Chevrolet Orange Paint
Heater box cover 60-70 gloss black, more gloss than firewall
Heater hose fittings silver cadium dichromate
Hood hinges grey or black phosphate
Hood latch assembley grey or black phosphate
Hood latch assembley spring 60-70 gloss black
Horns 30 percent gloss paint
Horn relay silver cadium dichromate
Horn clamps silver cadium dichromate
Intake Manifold Aluminum Natural aluminum finish
Intake Manifold Cast Iron Chevrolet Orange Paint
Intake manifold bolts 302 "TR", "M", "A" silver cadium dichromate
"L" bracket, holds master cylinder switch to stud on brake booster 60 percent gloss black paint
Leaf Spring Shackles 30-60 percent gloss black paint
License plate mounting bracket 60 percent gloss black paint
Master Cylinder 60 percent gloss black paint or Natural metal finish
Master Cylinder Cover Gold cadium dichromate
Master Cylinder Cover retaining wires Natural metal finish
Oil Cap 67-69 Z28 & L78 Chrome
Oil Cap fill tube 67-68 Z28 Chrome
Parking Brake Cables Natural metal finish
Power Brake Booster Gold cadium dichromate
Power Steering Brackets /Braces 60 percent gloss black paint
Proportioning valve 60 percent gloss black paint or Natural metal finish
Proportioning valve bracket Gold cadium dichromate
Pulley Crankshaft 60 percent gloss black paint or grey phosphate
Pulley Power Steering 60 percent gloss black paint or grey phosphate
Pulley Water Pump 60 percent gloss black paint or grey phosphate
Radiator Full Gloss Black
Rally Wheels Semi Gloss Argent Silver Front, Semi Gloss Black Rear
Rear Axel Housing 30-60 percent gloss black paint or Natural metal finish
Rear Back Backing Plates 30-60 percent gloss black paint
Rear Tail Light Panel SS 396 Semi gloss black paint
Rear Wheel Wells Black undercoating
Shift Linkage Black or Grey Phosphate
Shock Absorbers Semi Gloss Grey Paint
Spark Plug Shields silver cadium dichromate
Spark Plug Wire Loom Brackets Chevrolet Orange Paint
Starter Motor 30-60 percent gloss black paint
Starter Motor Brace 30-60 percent gloss black paint
Steering Box Natural metal finish
Steering Knuckles Natural metal finish
Steering Linkage Natural metal finish
Sub frame 30 percent gloss black paint
Sway Bar Front 60 percent gloss black paint or Natural metal finish
Sway Bar Brackets 60 percent gloss black paint
Thermostat Housing 67-68, 302 Silver or Orange Paint
Thermostat Housing 69 aluminum intake Natural aluminum finish
Thermostat Housing 69 cast iron intake Chevrolet Orange Paint
Throttle Rod silver cadium dichromate or Natural metal finish
Timing Chain Cover and Bolts Chevrolet Orange Paint
Traction Bar 1967 only 30-60 percent gloss black paint
Transmission Natural aluminum finish
Transmission Cross Member 30-60 percent gloss black paint
U bolts, Drive Shaft Natural metal finish
Valve Covers 67-68 Z28 Chrome
Valve Covers 69 Z 28 Dull Aluminum Finish
Valve Covers SS350 Chevrolet Orange Paint
Valve Covers 69, 396 & 427 Chrome
Voltage Regulator Gloss black painted cover with silver cadium dichromate base
Water Pump Chevrolet Orange Paint
Windshield pump washer cover Black Plastic, Natural Finish
Wiper Motor Gloss Black Paint
Engine build looks good Mike - and how did the Op go? Are you Mr Titanium now??
So approximately how much coin would one have to spend to purchase all of the "correct" paints for a complete resto? just curious.... Whew!-- that's alot of paints!
Discussion starter · #1,312 ·
hey todd, there are really only about 5 or 6 finishes in total. 3 blacks, 2 phosphates, and some natural finishes, other than body colour. makes it easy, that is for sure. the list really helps as well. sure is helping me make sure i am not all over the map. just depends if you mix the paint yourself or have a source. i went with sam trim black for the 30 percent gloss. 60 percent was mixed by the body shop. some semi gloss was done by the powder coater. natural finishes were done with several methods, from 3M pads, to glass beading to reverse electrolysis to parts washer. phosphating is easily done as well if you ca boil water. its just time consuming detail work. so far i am pleased with all the results.
Discussion starter · #1,313 · (Edited)
Update July 21, 2012
Since I am laid up with just one wing, I am using this time to collect more parts. Here are a few more updates.
Here is the intake after glass beading. I filled all of the intake runners and any other openings with rags and then sealed them up with cloth gaff tape to prevent any media from getting inside. Same process was applied to the harmonic balancer and water pump as well.
I like how they turned out. Next they go into primer and await paint.
Heads are installed with a thin gasket for better quench. I will post specs at some point.
I decided to go with stock 1.5 rockers as well as the stock 30/30 solid cam. I will post those specs as well when in get the info from Jack, the engine builder. We discussed the build and the options and we decided to build a reliable old school motor that will sound right, look right and be reliable. Also trying to get the build done on a minimal budget. I went with the 350 LT1 because it is very similar to the 302 and will also look the part for the Z28 clone project. It should perform fairly similar and it shares all of the same components and accessories perfectly. The only give away that it is not a 302, will be the engine pad stamp.
Carb will be a Holley 780 CFM VS List 4053, using the cowl hood air cleaner as well.
Looks good Mike - what valve springs are you using?
Discussion starter · #1,315 ·
Not sure on all the specs Tim. I will get all of the specs from Jack and post them soon. Ever since getting injured I am farming out as much work as I can afford, since I won't be able to do any wrenching for a while.
Mike, you are the man but you need to stop talking about a budget. I don't think you have a budget. That is a nice car and only getting better. Looks like you are feeling better. Keep up the good work.
Discussion starter · #1,317 ·
Thanks Terry. Too funny! lol. I do feel a bit better 3 weeks later. I can't wait to be able to pick up where I left off. Anything new with your car? It turned out amazing IMO. Inspiration for me indeed. I hope to get my car done by next spring. That is my goal.
Discussion starter · #1,319 · (Edited)
Update July 23, 2012
Here are the specs for the cam we went with. We are building this motor as close to original stock as possible, no roller rockers, hydraulic cam or roller cam here. Hopefully it will perform well. There are so many different options and ways to go with an engine, build, but sticking to stock should help achieve a similar to stock feel for the impostor build. I am hoping that this motor will give me a better performance than the 302. I guess we will find out soon enough.
Making sure that the intake is flat and provides a good fit on the heads.
Comp Cams guide plates
Refinished flywheel. Motor is balanced.
Block is an original bore truck block with 4 bolt main bored 30 over. I had considered the idea of doing a DZ clone block stamping, and even thought that a decked pad was an option, but since this is a straight up clone, I figured, best to leave everything as is is so it presents exactly like it is. This way all the numbers everywhere will tell the true story, all of which can be verified.
Water pump and harmonic balancer in primer. Final paint soon.
