69 upper cowl/wiper arm pocket paint/color
1 reading
4.3K views 15 replies 8 participants last post by  srode
I'm getting ready for Daytona Yellow paint code topcoat on my 69 project, and questioning myself. Isn't it black under the upper cowl panel, with the paint code color extending over the front edge of the panel to the start of the firewall?
Pics would be appreciated, and thanks in advance,
Mark
I believe it is body color inside the "cavity" under the cowl. I think the exception is if it has Z/28 stripes. Then the "cavity is somewhat sprayed the color of the stripe so when looking through the panel yousee the same color as the stripes. DO YOUR HOMEWORK ON THAT. I may be wrong. As far as firewall, the black came up close to the edge but does not have a fine line taped off.
Was body color from the factory except Z/28 which was painted stripe color.
edit...a little slow here :eek:, what Brian said !
Alright, thanks guys..!! This will have the rally stripes. So is the color in the cavity fully stripe color, or just directly under where the stripes are in a loosely somewhat "oversprayed" appearance??
Thanks again,
Mark
The paint would be the entire top of the cowl except the corners by the door hinge area. You should not be able to see it through the fender/ cowl gap. It stopped at the edge where the firewall started. No hard tape line. They held a piece of hard foam against the firewall and just blew it in. vega$ had a good picture of his first orange 69 Z that showed it. He was doing engine work in the picture hopefully he will re post it. Here is what mine looked like. Mine is a 05-a Norwood car.
