Best subframe connectors??????
20K views 26 replies 15 participants last post by  ilikeike
G
Who makes the best subframe connectors? I would like them removeable if possible. I want to put them on my 69 RS/SS convertable. The reason if I should sell it I would like to return it back to stock. Thanks,
Mike
The only convertible only connector out there is made by Global West. Myself and a hand full of Team Camaro guys have them installed.
They bolt in up front and weld in the rear. I guess you could put in a couple of bolts through the rear frame rails instead of welding them in but it will not be as strong and you will be left with holes in your frame when you remove them later on.
There are a couple of other ways to get connectors in your car but you are going to have to cut the floor or cut the connector and weld them in.
If you search around this site you will find many posts and pictures on the subject.
If you go to this link you will see a pic of the Global West Connectors on my car. http://www.ragersworld.com/images/subframeconnectors.jpg
Remember this about Global West connectors-
1. they hang 3" lower than your floor and if you are planning on lowing your car they will scrape every speed bump.
2. they are very visible.
You may also want to read this past post on convertible connectors http://www.camaros.net/forum/Forum7/HTML/002040.html
69 RS Convertible Camaro, 350/350. Orignal red with black top and interior. Hotchkis suspension.
[This message has been edited by jrager (edited 07-19-2002).]
SO what about us guys without the access to a welder? I though about getting the bolt on ones, and then taking to a shop and having them welded to keep their position. Will tis work, or should I just bite the bullet and pay for someone to weld on the weld in only connectors. I really don't want to mess with the floorpans, and the DSE bars are pretty expensive.
Dan
67 Pro-touring Camaro-327, 9:1, Comp XE268 Cam, Perf. RPM Intake. 750 Holley, Sportsman II Heads, Ceramic coated headers, 700R4 trans, 17" Amer. Racing TT2's, 12" disc brakes, custom stereo, black with white stripes, cowl ind. hood.
I recently installed the DSE SFC's and I love them. Very well thought out, perfect quality, great instructions. Yep, you have to cut the floor.
It is an interesting proposition. If you really want SFC's, don't buy the bolt in ones. You really wouldn't believe the stress you put on suspension pieces when you drive a car hard. And do SFC's work? Depends on the car, but the short answer is YES!!! I installed some on an 89 Mustang that I had years ago. Before install, when I jacked up one front side of the car, the front tire would come off of the ground while all others stayed. Afterwards, I could jack the car immediately behind the front wheel, and the back wheel would come off the ground virtually at the same time the front did.
It's a tough one, but one of those situations where it is difficult to have your cake and eat it too.
Mark
69 SS, ZZ430 Look-alike, Tremec TKO, Hotchkis Suspension
That's what I'm doing. I don't want to cut the floor up any more than it has been already. It sure won't hurt MY car. It's been on life-support for a looooong time already and it can't take much more surgery.
Joe
WCA Member
1969 Wallet Crusher
- HwyStar@Rochester.rr.com
- HwyStar@CarJunky.com
My neverending project!
#11 ·
I have the GW connectors. Jrager's caveat is right on the money. I like them very much.
Mine are welded both at the front and the rear instead of bolting on the fronts.
Check my link to see a couple of pics of how low they hang. By the way, I highly recommend some kind of SFC for convertibles. The car drives so tight and solid now. I thought it was fine before the install--then I had them put in to help curb any future sagging.
Like night and day. Also, make sure you have all the cocktail shakers as well.
68 Camaro ragtop, original 327, angle plug Camel humps, 202's, Performer, Holley 650 double pumper, Doug Thorley headers, 3-speed Saginaw, 3.08 posi, subframe connectors, Addco sway bar
http://hobbystage.net/camaro/cjkaram/
#12 ·
Mark-
Thanks for that. It really isn't all about the saved money, it is about not cutting into the floor pans of my already finished car. Glad to here someone is running that setup and having good results. I will go the bolt in, then weld route, as I refuse to cut the floor pans. Thanks
Dan
#14 ·
I refused to cut up my nice new floors in my "Pro-Tour" Pace Car. I made my own connectors to fit under my '69. I simply bought Jeg's bolt in connectors (I didn't want to permanently weld any in) and notched and fully boxed them in. Cost $100 bucks and NO they won't scrape the ground, and my car is lowered 2-2.5 inches. As a matter of fact the Global West connectors hang lower than these, and are much more noticable. Here is a pic, I hadn't painted them yet as I was still fitting them. Yes, anything is better than nothing, and these stiffin the chassis remarkably well.
[This message has been edited by CrossRamZ11 (edited 07-21-2002).]
#20 ·
Winch,
I purchased the Jeg's brand because the stated that they are "60% stiffer than the competition" Meaning CE
connectors. I don't really know if that's true but oh well, they are good enough for me.
1969 "Touring" Pace Car, Full Hotchkis Suspension, Bilstein Shocks, AGR Steering, 352CI Dynoed 470hp/430Tq - Winston Cup Airbox, 18" Centerline Lazers, Baer Track Brakes.
1969 Touring Pace Car
[This message has been edited by CrossRamZ11 (edited 07-22-2002).]
#27 ·
Since I just finished my floor and installed the interior I didn't want to take it all apart to install the Detroit Speed style SFC,they look the best.
Second best in my opinion is the Hotchkis, thats what I went with. I think the rectangle tube they use looks and fits the car the best.
