Will be pulling the Engine, Transmission, and heater box out of a 68 Camaro Convertible.
Can someone recommend correct sequence of parts to remove? I tried searching on it but came up empty?
I might suspect?
I know a lot of you don't remove all this just to pull an engine but since I have to remove the passenger side inner fender to remove the Heater Box I might as well make it easy for my self and remove everything else since I will be pulling and install the engine and transmission by myself.
Thanks in advance.
I might suspect?
- Battery
- Hood
- Bumper
- Front Grill and Headlight assembly
- Lower valance
- Left and Right Fender
- Left and Right Inner Fender
- All Hoses and Wire Connections
- Drive Shaft
- Radiator
- Heater Box
Thanks in advance.
