My return spring is in the large hole that the new stud will occupy - but there is a much smaller hole just next to it that the return spring should actually be in at present. That small hole might not exist on all carb throttle controls, as I see there are a couple of variations. When I install the stud in the large hole I'll move the return spring to the small hole and should be OK. I'll need to experiment some with the kickdown adjustment. I don't want to be pulling on the kickdown rod every time I accelerate but will need to figure out how much that rod needs to move before it actually engages the kickdown.
I see the longer rod available at a couple of different sources, which is good. The Assy Manual actually shows the short rod as the correct part for all 327s, but we know that's incorrect. The manual shows the longer rod for larger engines but should also state that any 4 bbl carb will need the longer rod.
