Hey guys - sorry in advance if this has been covered multiple times. I searched, but didn't find what I was looking for.
I have a 1967 RS/SS (at least I think it is) coupe. I pulled the carpet out, intending to replace it and add some insulation and found a less-than-desirable repair had been done to the shifter tunnel.
The shifter stick says "Muncie," but it's bolted to a Hurst shifter. I suspect a previous owner hacked the tunnel up to get the Hurst installed. The tunnel bits that were cut away were covered up with a thin layer of sheet metal riveted in place.
Is repairing this properly just a matter of welding in the repair panel (Part #:
33-185807-1 at Rick's Camaros)? Are there any other pieces needed for reinforcement?
Hoping I can put a couple of pics with this post. Let me know if different pics would help.
Thank you!
Thank you!
