VIN Tag Rivets
16K views 19 replies 11 participants last post by  6781camaro
What kind of rivets or fasteners should I use to install the original VIN tag on my new cowl. I doubt the original ones are still available, right?
#3 · (Edited by Moderator)
Someone has the original rosette style rivets but I cannot remember who, but we just use regular rivets. We're trying not to pull anything over on anyone when we replace a dash top, and they go in upside down anyway, the the ugly side of the rivet is what you see if you look under the dash pad. Unless it is 67 then that is a entire different story as the vin is in the door jam and the rivets show.
Hemmings might be a place to look for original rivets
VIN or Trim Tag? The rivets pictured above by Ron are for the TT. Did you mean the TT on your cowl of the VIN on the dash top?
#11 ·
I looked into this a little while ago when I removed my original cowl.
Here ya go everyone...
Joe Papier
Trim Tags, Inc.
900 Port Clinton Court West
Buffalo Grove, IL 60089
847-478-TAGS
joe@trimtags.com
#13 ·
Here's another source I just found simply by googling "rosette rivets Camaro". It is an ad placed on this site: http://restored-classics.com/ohio/ SEE BELOW...
June 2009
1970 Olds 442 and cutlass - parts for sale -restoration rosette rivets stainless steel silver 1965 to 1980 chevrolet chevy Oldsmobile Pontiac buick
corvette cutlass chevelle gto lemans 442 skylark gs delta 98 stainless steel silver in color $32.00/pair includes shipping to 48 U.S. email for pictures
ericsolds@sbcglobal.net cleveland, OH
#17 ·
Wasn't there a VIN number stamped inside the lower cowl somewhere from the factory? I looked on the original cowl but couldn't find it. Any specifics as to where it would be located? I'd like to cut it off before I throw the piece away.
THere are TWO locations that have hidden vins stamped into them.
  1. just below the heater blower motor hole on the pass side tulip box
  2. on top of the inner cowl assembly just to the right of the center on the top surface. You'll have to remove the cowl panel to see it.
Check my thread for pics. I went through the same things....
