What 8-to-5 crazy do you deal with?
6K views 35 replies 25 participants last post by  RSSSfanatic
I thought I would start this thread to see what everyone else has to deal with during their 8-to-5 wage earning time. Idea is to post something (picture, lingo, crazy talk, etc..) that represents what it is that you do from 8-to-5. The more sense it makes to you and less to everyone else the better. So, I’ll start with mine… BTW, I hate my job as I waste my brain all day :clonk:. I would like to quit, open a Subway shop and hopefully the only thing my brain would need to process is to see if the guy in front of me wants mayo or mustard on his sandwich… :thumbsup:
Either doing this:
for i in *${RF_DATA_FILE_SUFIX}
do
export rfFile=`echo ${i}|cut -d"." -f1`
echo ${RF_FILE_TO_CF_SCRIPT_XREF} |grep ${rfFile} >/dev/null 2>&1
rc=${?}
if [[ ${rc} -eq 0 ]]
then
log_event "Validating subscription for file: ${i}. Status: VALID."
else
log_event "Validating subscription for file: ${i}. Status: INVALID."
log_event "Continuing but notifying OPS..."
mail -s "${script_name} - Warning: Unknown RF File" ${MAILTO_GROUP} <<!EOF!
`echo "File ${i} is not part of current subscription."`
!EOF!
fi
done
Or this:
7 to 3 here Matt
and I get plenty of stimulation for my brain in the machine shop where I work where we make shafts or repair bearing fits, seal fits, bore couplings and sprockets maybe a little balancing and cylindrical grinding.
What drives me crazy is when we get a new manager come in and he's gonna change the world. I've outlasted them all. ;)
I fix undeground telephone cables all day working in manholes.Most people dont know that underground phone cables are continously pressureized with dry airto keep water out.I get to fix everything from the compressor/dryers that supply the air,the pipes and manifolds that distribute the air to the leaky cables that need the air.Of couse my group is called the "Air Gang".We use an electronic system to monitor the pressure in the cables and the flow and pressure from the manifolds using pressure and flow transucers that set off alarms when the cables go below 5 psi,the manifold go below 7 psi,or the manifolds exceed the specified flow rate.Then I go out into the field pulling manhole lids,reading the pressure on the leaky cable{s} and caculate the location of the leak using pnumatic resistance formulas based on flow rate,cable size,gauge and insulation type.I get to do lots of lea wipng{just like the old bodymen} on the old lead sheathed cables that crack or corrode which is just as much a dying art in telecommunications as it is in bodywork,but if you can do it{few guys can} you can be the go to guy on the big cable failures that usually require these kinds of repairs.My boss gets rated on how low he can get his alarm percentages and how few cables fail under his watch.He doesnt really tell us what to do.He gives us{a team of 2 guys)an area {town} to work in.We walk in the office every morning and pull up an alarm report for our area and fax him a sheet with where we are going,and unless he has something more imporant,thats how the day is gonna go.If we get the alarm rate down to acceptable levels(typically takes months to do)and keep the cabes from failing he doesnt want to know we exist.If I want overtime and my area is up to snuff,I will go pull up alarm reports for other areas that are being neglected and mop up the mess there.Since our gang is mostly old timers looking to mozy thru their final years,and only handfull of us younger guys really want the work,the overtime is ripe for the pickin.It truly a job where once you learn the science of how to calculate where the troubles are you can really write your own ticket.
So now you know.
8-5 here and school 6:15 to 10:30 everynight m-f. I work at a transmission shop installing and pulling transmissions and any other drivetrain related stuff. However we do absolutely everything related to a vehicle from pulling and rebuilding a motor to putting an ash tray in. I go to school for diesel. I figure all the experience i can get will help.
9-5:30 as an electronics technician repairing video and redemption games,batting cages and Laser Tag vests in a FEC. Oh, and dealing with kids who have no respect or try to scam you, parents who think a redemption ticket or token for the cheap Chinese crap we give away is worth gold, or the ones who; if anything goes wrong it is" ruining their experience" and it's my fault. ****ty managers who can't and won't control the young teens we hire, who won't delegate responsibility, who won't do anything about the F$%%ing cell phone usage by said teens, who hire back people who quit,who put unqualified people in management positions. A corporate office that, while buying up more stores, haven't given a raise to anyone in 3 years,refuses to administer drug testing to avoid the cost. Oh yes. This is my hell.
Working on my Camaro helps keep me sane.
Anyone need a good tech in Dallas? Seriously?
#12 ·
I hear ya DJD.There is a lot of that around here.We use white tanks though.It sounds like they are using Hydrogen tanks which are really only a small part hydrogen.Thats a pretty good idea.We use smaller Nitrogen tanks which only start out at 200 psi and wont last all night if you leave them set at 5psi pumping into a leaking cable.Hydrogen tanks are bigger and have 2000 psi in them,the should be good for an entire week.Why change the tank everyday when you can do it once a week and just tell the boss you are doing it very day:) Scam artists,all of them.
#18 · (Edited)
:cool: - I used to do quite a bit work at that site in several buildings.
Did a lot of 'shut-down' major installations of HazMat distribution and control 'thingies' ...
I work at a little calif oil company as an ‘SR. Asset Developer’(CSOC Certified of course) – Pretty much an 8~5 thing ...
I take the CVX-CBRES/NAFL(downstream) Capital Project Proposals and then formulate and complete the FEL/Engineering for the 1st Phase CPDEP presentations to the DRB.
Then my group develops the project through Phases 2 & 3 CPDEP with ICE support and engineering oversight.
Completion of all supporting OE/BBS/CSOC documentation must then be attached to support the project metrics.
I then construct the final Phase 4 DSP documentation and present it to the CGB to finalize the funding ... then we’re off to the races with contract submission to our CHESM Certified Core GC’s involved. :thumbsup:
It all goes pretty smooth – unless of course you’re ADAIRO presentation doesn’t support the alternative development and choice, or your DSP has an undocumented RR or LL compliance issue :sad:
Then I just "re-align" my team, snake all the 'key' stake-holders again and "recycle" to an alternative for presentation at the next DRB - then we do it again as needed ...
Never hurts to "Coffee Pot" the Decision Executive(s) and the Endorser to get their Value Driver Analysis for items to be included "On the Frame" before your Decision Hierachy is submitted though ;)
Must be why I find cars and boats so simple and relaxing ;)
#14 ·
Rich I thought the green was for non-flamable gas, I'm fairly sure they use Nitrogen too. You're right, our guys used the tall bottles... Funny once the old pressure guys took a package or retired they were replaced with middle age techs and the Loc Mgr decided it was less expensive to bottle sit than get the guys training on chatlos and trouble shooting. That's the way it was told to me anyway, I supported engineers until I was layed off in 2008...
#17 · (Edited)
Yes, that's Informatica alright! Glad to see more "geek-heads by day and gear-heads by night" out here. I guess I never did say what I really do ... I am a contractor for DOD. Do a lot of health care data warehousing for the US Military. Anytime a US soldier or his spouse/child sees a private or military doctor/hospital a medical claim is submitted and eventually paid by the US government. The systems/applications I build and maintain ultimately validate, process, accept/reject and pay these claims. I move billions or records around various DB2 UDB databases using tools like Informatica, UNIX, Cognos. Few years ago my team wrote an application that finds duplicate claims "accidentally" submitted by private doctors to the DOD multiple times for payment. That application recovers close to 20 million $$$ per year now. Also designed a datamart for fraud and abuse analysis where we found some interesting stuff, like the 80 year old guy that was getting weekly prescriptions for 400 Viagra pills. Turns out the doctor was running a scam and selling the pills himself on the black market.
I used to like my job a whole lot more than I do now as working for the DOD is painful majority of the time. Big ship, changes are very slow or next to impossible and the decision making process is simply unbelievable. You don't know how many times I've been told that 2+2 is 5 and the earth is indeed flat... Good news is that DOD is good client to have as they have deep pockets and not very likely to go out of business anytime soon.
#16 ·
Yeah Dennis,we loose a lot of experiance with every buy out.We are loosing a few more in the next few weeks.They dont really train guys anymore.I think if they replace anybody in our gang,they will just bring over some cable splicers and pair them off with air guys to learn or just be "top of the hole guys".
As for non Flammable gas,the hydrogen is classified as non flammable because it is something like .05%.we normally use it for leak locating underground sections by pressurizing the cables with it and running a sniffer around all the bore holes and patches in the ground until we find something.We use Helium for that too.
I still pull up a Chatlos report every day for my areas.It's not too hard to do.In most cases a boss would normally do it,but since we dont have a boss in our office{we remote report} we have to do it on our own.They are always moving people around in the offices and every time we get a new support staff,we have to walk them thru using the monitoring systems.If I am out in the field and want to see if an alarm cleared after I fixed something I have to call in and walk them thru it.My boss doesnt even use the system and I am not sure he knows how{he was an air guy but waayyy back when).he gets a report from 2nd level once a month with the overall numbers for each area.when things look good{warm weather} we get lots of atta boyz,when things tank{cold weather} he leans on some guys a little.It isn't too big a deal.As the old timers tell you when you walk in the door for the first time,"Theres no pressure in air"
#19 ·
12am-8am weekends, 8am-4pm weekdays
radiologic technologist.
I do xrays on people who come in to the emergency room and tell me they hurt their ankle A WEEK AGO!!! arrgggh!! so much for calling it an emergency room.
so now when people ask me what I do for a living, I just say I'm a population control specialist :D
#21 ·
radiologic technologist. so now when people ask me what I do for a living, I just say I'm a population control specialist :D
Where do you work Steven?
I'm also a tech. Used to tell people I wrestled old women and tormented young children for a living. :D
Have worked as an angio/cath lab tech, lead OR tech, evening supervisor, instructor, ortho tech and an ER tech. Now after 25 years I'm living the good life in an OP clinic.
Mark
#20 ·
m-f 6am-5pm
internet proctoligist
#23 ·
Mine is more of a 5am to whenever I get done, usually around 2pm, 4 days a week. I deliver beer part time Tues, Wed, and Fri, and help the salesman, who is the biggest crybaby I know, on Mon. I've been in the beer business for about 17 years and this guy is the worst I've ever met. But, at the end of the day I go home and work in my shop til about 12am turning wrenches and slinging bondo.
#24 ·
Mine is more of a 5am to whenever I get done, usually around 2pm, 4 days a week. I deliver beer part time Tues, Wed, and Fri, ...
:hurray: We have a winner !!!!!! :beers:
I want to do that when I grow up :thumbsup:
#26 ·
I basicly set my own ours, but its usually 9a to 9p, I am a paintless auto hail damage repair tech. My compny is National Dent Inc. I follow hail storms all over the US, set up shop, and repair as many as I can, then on to the next storm. My work is seasonal. March-Oct then I go home and work on the Camaro. If your thinking about buying a new Camaro, DONT touch the quarter panels or you will dent them!! They arent made of anything! Anyway, its a very rewarding job and I get to buy up camaro parts all over the US!
Jason
#36 ·
I had a particularly nasty looking dent repaired by one of the paintless dent repair guys on my wife's Altima, and I was very impressed with the job they did. Almost like magic to me. I have a very annoying ding on the quarter of my 67 that I might give them a shot with.
#28 ·
I'm a final test engineer on MOCVD semiconductor manufacturing equipment. Also 3rd shift supervisor. The equipment we build is used for manufacturing LEDs, lasers, etc. I have to do electrical troubleshooting/repair, pneumatic systems, helium leak checking, software configuration and more while trying to keep workflow at an acceptable level from techs that can barely walk and chew gum at the same time. Here's a short movie of the equipment I work on: http://www.veeco.com/movies/TurboDisk_01_K465 GAN.wmv
#29 ·
I'm a soldier in Iraq ATM. Hours are whatever time they wake me up to fix w/e is messed up to whatever time messed up equiptment is fixed. There has been some 24+ hour days which I hate, all while in 120+ degree heat. I broke my hand last november, that made it even worse.. ever tried to fit your cast and the only 2 fingers on that hand you can use into a small space to screw on a nut? It will make your temper go through the roof. And before someone asks.. i had to use my other hand to hold the part up!
Shawn
#33 ·
Shawn
Thank you for your service Sir.
#32 ·
:confused: So you're an arsonist Scott ...
(winky winky winky J/K and all of that ...)
