Another 69 build
9K views 61 replies 21 participants last post by  67speedfreak
Just thought I would share a couple pics of another 69 project in the shop. I know how you guys like pics. :D
This car will be a full pro touring build with complete DSE suspension and a blown 427ci LS.
:popcorn: SWEET! Another masterpiece in the works! We do love the pics and again, your work is quite admirable. :yes: Looking forward to seeing this one come to fruition as well. I am sure I will learn some more on this build too. Thanks for sharing.
talk about building from from the ground up...sounds like a nice project you got going on!!..gotta love pics!!
#23 ·
Brian,,
Looks very nice..
Dave C,,,you need to get off your a$$ and start on your sons car. Do you have a heater in your shop....
Yes but not enough money for propane at below twenty degree's here in Md..I hate to spend money and not for play time.We have his Explorer on the lift that needs to get done first....
Brian, the car looks great! What brand quarter panels and tail panel did you use on this car? The fit from the quarter to the tail pan looks very good. I need to buy quarters and would like to find out what a professional like yourself uses. Thanks Dan
Thanks Don
I use mostly Dynacorn sheet metal, That is what we are using on this car.
Don't let the pics fool you there will be alot of massaging to get these parts to fit right.
#15 ·
Brian, you make it look like those panels just fell into place but I know that is not the case (unless you have a secret supplier). Those gaps around the tail panel look perfect. I am impressed as usual.
Don
#26 ·
Brian--
You never cease to amaze me. Nice work! Looks like it all just fell into place tightly.:thumbsup: ( I know it's not that simple :D, but you make it look that way...)
Thanks for the inspiration.:beers: I'll be out there again someday soon on my Camaro too....
#28 ·
Looks awesome! I see you plugged from both sides of the trunk panel and frame rails. Did you do those plug inverted or pre-weld them before setting the trunk and rails into the body jig?
